Author Topic: Xbox and ultimarc AV adapter  (Read 3107 times)
Dannymh
  • Last login:December 23, 2011, 05:09:54 pm
« on: October 10, 2011, 07:28:19 pm »
I have a MAME machine and the computer blew a few caps in it the other day, so thinking I may as well hook up my XBOX as the new MAME machine in there. However am a little confused by the ultimarc site.
The monitor in my cab is a pentranic 25khz/15khz monitor. Reading the site, it says that you need the xbox to JAMMA connector. The issue for me is that I do not have a JPAC or JAMMA in this cabinet, will this matter?
I need to get the XBOX to iPAC adapter, I am just unsure on the AV side.
On ultimarc it says for multires monitors, the jpac AV adapter is needed, but I am just not clear on whether it matter or not that I do not have a JPAC and/or Jamma.
The monitor used to be hooked up to an Arcade VGA and the amplifier is still there, so just not sure which part to order
Can anyone clarify for me?
Cheers
Dan
« Last Edit: October 10, 2011, 07:32:54 pm by Dannymh »
SNAAKE
  • Trade Count: (+29)
  • Last login:Today at 09:55:58 am
  • my joystick is bigger than your joystick !
Re: Xbox and ultimarc AV adapter
« Reply #1 on: October 10, 2011, 07:37:45 pm »
pretty sure the ultimarc av cable will still work without a jpac. standard 5 wires from your arcade monitor goes on the av cable. you should email ultimarc before ordering.
« Last Edit: October 10, 2011, 07:41:42 pm by SNAAKE »
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
« Reply #2 on: October 11, 2011, 10:47:09 am »
I think snaake is right, they are independent.  Just like your gamepad doesn't have anything to do with your TV.   ;D  Wouldn't hurt to check with ultimarc though.
sharpfork
    • KADE
« Reply #3 on: October 19, 2011, 12:15:09 am »
I'm pretty sure the video cable snaake posted will do the trick.  Andy from ulitmarc will know for sure.  I'm testing a few otpions for relacing a pc with an old xbox in a Mame cab and the quality of the ultimarc iPac -> xBox one converter is spectacular!  I highly reccommend it.
For the software side, check out coinops 2 and soon coinops 3.
