Author Topic: Switching frontends, looking for recommendations  (Read 1830 times)
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« on: October 08, 2011, 04:38:44 pm »
Upgraded to WinXP SP3 and now my setup no longer works, figured it's a good time for an upgrade.  Hoping for some recommendations from those using other frontends.  There seems to be a lot of them out there now...
Currently using Advmenu which has all the features I need.  Ideally, a frontend replacement could do the following:
Rotate between vertical/horizontal w/ a button press.
Launch mame or misfitmame w/ the current rotation flags
Allow me to categorize and switch between categories w/ a button press.  Advmenu has 2 different sorts of categories which I utilize.  For one set I use orientation (horiz, vert) and the other set I do it by controls (2 buttons, 4 buttons, 4 way, 8 way, etc).  So I could for example look at all the horizontal 4 way games by switching each categories (each set is a different button).
Work/look ok on an arcade monitor
That's about it, anything else is gravy.  Only fancy feature I use is the audio snippets for games and screenshots.  I have my own frontend for launching advmenu and other emulators like daphne so if it could also do multiple emulators that would make things much easier...
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
Mister Hat
  • Last login:April 12, 2013, 10:05:59 pm
Re: Switching frontends, looking for recommendations
« Reply #1 on: October 08, 2011, 05:29:13 pm »
I'm pretty sure MameWah (or WahCade) has all of what you need and is pretty basic by default. Very customisable and runs very lightweight. I recommend it.
« Last Edit: March 22, 2012, 08:49:35 am by Mister Hat »
zorrobandito
  • Last login:October 04, 2025, 12:11:09 am
    • Zorro's Classic Games
« Reply #2 on: October 13, 2011, 09:38:13 am »
I did an assessment of the top 5 (GameEx, Mala, Maximus Arcade, Atomic FE and Hyperspin) as an alternative to mamewah a few months ago. It might interest you.
Mister Hat is correct, MAMEWah will fulfill your requirements.
