Author Topic: HAPP WHEEL / SERVO / FFB HACK - 1st Racing Cab Build. My Notes  (Read 37015 times)
ScottoKong
  • Last login:June 10, 2018, 08:57:46 am
Re: HAPP WHEEL / SERVO / FFB HACK - 1st Racing Cab Build. My Notes
« Reply #40 on: July 23, 2012, 09:43:43 pm »
Meant to say to do whatever you like with the stuff I pulled together.
Its lucky I made the notes as I was going - heaps I'd forgotten!
I'll make an effort to get some pics together.
Happy to add it to your driving thread and create a new post
kanario40
  • Last login:August 28, 2025, 06:53:00 pm
« Reply #41 on: November 16, 2012, 12:29:38 pm »
I have bought a Sega TouringCar cabinet and I would like to do a Hack of steering wheel with a Logitech Driving Force Pro,but I need to know first if I can use the original steering wheel of Sega Touringcar cabinet this:
Uploaded with ImageShack.us
This motor it,s of 100 V and it has three wires instead of two.it can be triphased.
Does anyone say me if this motor I can use it with a servo ampli to a hack of steering wheel?
« Last Edit: November 17, 2012, 06:06:28 am by kanario40 »
« Reply #42 on: November 16, 2012, 01:09:29 pm »
Can't use the servo amp.  If it's the same setup that was used in the first Daytona USA or Sega Rally, it can be hacked via this method:
http://translate.google.com/translate?hl=en&ie=UTF8&prev=_t&rurl=translate.google.com&sl=fr&tl=en&twu=1&u=http://www.gamoover.net/tuto/l2m2-interfacer-un-ffb-et-volant-sega-model-12-avec-un-pc-ou-une-playstation-23
Looks like a lot of work, but the people that have done it are much happier than those with the happ/servo amp hacks.
RetroRepair has a couple STCC cabs and uses that hack.
Look him up on youtube.
kanario40
« Reply #43 on: November 16, 2012, 01:41:14 pm »
Thanks BadMouth by the information I want to do itself,it sems to have more work but it,s cheaper.I can use the transformer of the cabinet.
With that method of that link can I keep the FFB of original steering wheel or not?Can you give a explain about it?
« Reply #44 on: November 16, 2012, 01:52:05 pm »
Yeah, everything is kept original.
Might want to check with retrorepair and make sure that motor will work.
He has an account on here.
I can't really explain any more.  I haven't done the hack or messed with Sega feedback motors.
I do know that everyone who has that hack is much happier with it than the happ hacks.
kanario40
« Reply #45 on: November 16, 2012, 06:23:59 pm »
Thanks BadMouth other time I,ll I'll talk with RetroRepair.
johnriper
  • Last login:August 24, 2014, 03:23:14 am
« Reply #46 on: December 29, 2012, 08:35:09 am »
Hello i would also like to buy a l2m2 adapter if it is possible can you please help?
I have bought an old daytona usa cab, put a midway motor, a logitech driving force RX could not find EX, the amc servo amp, original logitech 24v power supply but with a simple voltage divider at the motor output, because RX dont work with 12 v power supply the motor output is zero, i have added the paddle shifter from f355 and a hand break from sega rally 2, but i have the problem everybody has with this hack and i would like to try the l2m2 hack if you can help.
thanks.
Here are some photos
