Author Topic: MAWS broken?  (Read 2033 times)
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
MAWS broken?
« on: October 05, 2011, 05:13:41 pm »
This is probably a stupid question, but I've not used MAWS for a while and now I come back to use it, neither browsing for roms nor searching is turning up any results. Is the site down or am I doing something drastically wrong?
Hoopz
  • Last login:Yesterday at 08:22:44 am
  • Intellivision Rocks!
Re: MAWS broken?
« Reply #1 on: October 05, 2011, 05:22:20 pm »
The site is up, which it wasn't a week or two ago.  But you are right that the search function isn't returning any results.
So, yep, its broke.
Turnarcades
    • Turnarcades
Re: MAWS broken?
« Reply #2 on: October 05, 2011, 05:29:21 pm »
It's not something I use often as I tend to do weeding and filtering manually for accuracy, but right now time's of the essence so is there something similar close to MAWS online?
Re: MAWS broken?
« Reply #3 on: October 05, 2011, 06:39:47 pm »
If I remember right, you can do certain filtering things with MameUI.
Turnarcades
    • Turnarcades
Re: MAWS broken?
« Reply #4 on: October 05, 2011, 06:44:19 pm »
Would have been my second avenue, but unfortunately not detailed enough for the filtering I need to do.
Donkbaca
    • Slim built MAME/Xbox cab
Re: MAWS broken?
« Reply #5 on: October 05, 2011, 07:17:26 pm »
it is down.  MiniMAWS is up though:
http://maws.mameworld.info/minimaws/
Turnarcades
    • Turnarcades
Re: MAWS broken?
« Reply #6 on: October 05, 2011, 07:58:22 pm »
Thanks for the link, but it's not that helpful in this case. A good backup if all else fails though.
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: MAWS broken?
« Reply #7 on: October 06, 2011, 10:52:52 am »
romlister is as good or better as any maws search+filtering query.  it takes just a bit more work to set up, but it'll never go offline!
http://www.waste.org/~winkles/ROMLister
randjamal
  • Last login:November 25, 2025, 04:30:47 pm
Re: MAWS broken?
« Reply #8 on: October 06, 2011, 11:17:38 am »
It's not as good as MAWS, but mamedb.com is passable when MAWS is down. And KLOV is often more accurate than MAWS for things like control type and orientation.
