Author Topic: WG K4900 Wave?  (Read 3321 times)
Bender
WG K4900 Wave?
« on: October 03, 2011, 12:46:54 am »
I have a WG K4900 in a tron cabinet
I recapped it and got the picture to look pretty good but I still have the phenomenon that looks a lot like when you watch video of an arcade monitor you can see the sync cycles go by, not sure what to call it really a "wave"? I'm a little hesitant to call it a wave because there is no real geometry distortion only a slight intensity difference that moves across the screen, the monitor is in the vertical position and the "wave" moves left to right
I think this may be a power issue but I'm not sure where to check the B+ and I don't think this monitor has a B+ adjustment
any input would be greatly appreciated
grantspain
Re: WG K4900 Wave?
« Reply #1 on: October 03, 2011, 01:29:05 pm »
could be an earth issue
Bender
Re: WG K4900 Wave?
« Reply #2 on: October 03, 2011, 03:18:39 pm »
Could you explain that a little more?
ed12
Re: WG K4900 Wave?
« Reply #3 on: October 03, 2011, 03:37:01 pm »
from what i can read the wg4900 has no voltage control :dc: side
i would chk chassic ground
rem this monitor need's to be isolated
most important
ed
grantspain
Re: WG K4900 Wave?
« Reply #4 on: October 03, 2011, 03:59:13 pm »
you should check the earth from your wall socket has continuity onto the power supply,monitor frame and any exposed metal parts of the machine
if you have a switch mode power supply you can try to link the earth to ground
ed12
Re: WG K4900 Wave?
« Reply #5 on: October 03, 2011, 04:18:11 pm »
here >http://www.mikesarcade.com/arcade/monitors.html<
use firefox,it want's it, u will find both schematic's for that series there
regards
ed
MonMotha
Re: WG K4900 Wave?
« Reply #6 on: October 03, 2011, 05:08:05 pm »
This usually does indeed seem to be an ground (earth) related issue.  It sometimes helps to add or remove, as appropriate, a link between DC power common ("ground" aka the black wire) and earth ground (the green or green/yellow wire).  Also make sure that the monitor frame is connected to earth ground.
I've also had this be an issue with a faulty AC bulk smoothing cap right at the input on the monitor before the regulator; this cap is generally not included in "cap kits" as it doesn't go bad as often and is big and expensive.  A bad cap at the output of the B+ regulator could also be a cause, I guess, but these usually are included in cap kits.
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
Re: WG K4900 Wave?
« Reply #7 on: October 03, 2011, 07:26:59 pm »
Hum bar is the term for what you have there. I hope you checked for cracked solder while doing the cap kit.
Anyway, I've seen this issue in games caused by dirty fuseholders and/or fuses.
ed12
Re: WG K4900 Wave?
« Reply #8 on: October 03, 2011, 08:45:04 pm »
boardjunkie i was thinking hum-bar
but the nick states
that put's me in mind of a crappy ground somewhere >cold solder joint's<
and or a leakey by-pass
1mf or less cap
ed
Bender
Re: WG K4900 Wave?
« Reply #9 on: October 03, 2011, 09:22:58 pm »
Thanks everyone!
Weirdest thing...
I'm messing around with the 5v pot on the PS cause I'm trying to get a NVRAM back-up for the high scores to work and discovered if the 5v is turned all the way down which is about 4.8v there is no Hum bar, the monitor looks rock solid (but said NVRAM backup does not work)
I didn't even think the 5v was in any way connected to the monitor :dunno
There is an earth ground to the monitor frame
a ground strap near the coin door isn't connected to anything, anyone know where that is supposed to go?
seems like there is some weird electrical thing going on some where in there
how do I test this stuff to try to isolate the problem?
Any ideas?
« Last Edit: October 03, 2011, 09:25:33 pm by Bender »
Bender
Re: WG K4900 Wave?
« Reply #10 on: October 08, 2011, 08:50:34 am »
Sorry to bump this but, I could use some help on how one would test for ground/earth issues
grantspain
Re: WG K4900 Wave?
« Reply #11 on: October 08, 2011, 12:07:43 pm »
multimeter set to ohms and then meter every earth connection or metalwork back to wall plug-expect a range of readings due to resistance but you are aiming between 0 to 5 ohms
if all that checks out then post a photo of your power supply
