Author Topic: How do I wire the PC power from MB to button?  (Read 2792 times)
Cougar888
  • Last login:September 22, 2013, 02:50:09 am
« on: October 01, 2011, 11:29:15 am »
Hi guys, right I want to wire the PC power from the motherboard to a button on the back of my cab. I don't have any connectors for the MB so whats the best way to go?
Re: How do I wire the PC power from MB to button?
« Reply #1 on: October 01, 2011, 12:08:25 pm »
Cut the wires off the computer's power button and wire them up to an arcade switch (or some other type of momentary switch).
Cougar888
« Reply #2 on: October 01, 2011, 12:18:55 pm »
I'm guessing I'm speaking to the saame guy from the Hyperspin forum, if not it's spooky LOL I don't have a case which is why I don't know how to wire it. I was expecting to use the connector and wires in that way then realised I didn't have them :(
« Reply #3 on: October 01, 2011, 12:28:01 pm »
No, I don't post on the Hyperspin forum. You can sacrifice a USB header cable to hook up to the power header... Or salvage parts from a computer someone is throwing away...
« Last Edit: October 01, 2011, 12:29:36 pm by Nephasth »
Cougar888
« Reply #4 on: October 01, 2011, 12:31:35 pm »
Wow thats weird the guy on there gave the same answer almost word for word LOL I was thinking of cutting another header up but I don't have anything. I may have a PC speaker somewhere or could buy one as they're cheap, would that work?
« Reply #5 on: October 01, 2011, 12:33:52 pm »
If you've got a buck and some change, get this.
Oh, and link to the posts of my doppelganger... :)
Cougar888
« Reply #6 on: October 01, 2011, 12:38:37 pm »
LOL here's your twins reply: http://www.hyperspin-fe.com/forum/showthread.php?p=143112#post143112
I'll check out the ebay link cheers
« Reply #7 on: October 01, 2011, 12:40:27 pm »
Heh. There's always more than one way to skin a cat, but there also appears to be a preferred method. :D
Cougar888
« Reply #8 on: October 01, 2011, 12:57:33 pm »
LOL yeah, thanks for the help bud
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« Reply #9 on: October 01, 2011, 03:35:34 pm »
I just used an old power wire connector from a case and wired it up to a recessed button in the back.  Anything similar will do.   And to power it down for whatever reason, just hold i down like you would on a computer.  I i like to use the software in the frontend to shut the comp down.
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #10 on: October 01, 2011, 04:48:55 pm »
I wired mine into a phone jack/receptical so that when I need to remove the PC from the cabinet i've got an easy disconnect between the button wire (phone plug) and he computer (phone jack).
Cougar888
« Reply #11 on: October 01, 2011, 05:19:43 pm »
Where does the jack plug into on the motherboard?
BobA
  • What Me Worry?
« Reply #12 on: October 01, 2011, 05:57:24 pm »
It does not plug in you need to connect the black MB connectors to the Front Panel power pins and then wire to telco jacks if you want a quick disconnect.  Seems a bit complicated for you right now.
Cougar888
« Reply #13 on: October 02, 2011, 01:46:33 am »
Thats the thing, I don't have any of the black connectors. I thought I'd have at least an old header somewhere but nothing. I'll see if my local computer shop as anything :)
BobA
  • What Me Worry?
« Reply #14 on: October 02, 2011, 01:46:04 pm »
Most computer shops have tons of those double pin black connectors lying around.   The hard place to get them from is the big name shops.  Support your local computer shop.  ;)
Cougar888
« Reply #15 on: October 03, 2011, 01:26:52 am »
Maplins sell them so I'm bobbing down there today :)
