Author Topic: avga 3000 to jamma monitor  (Read 1526 times)
jahilton2002
  • Last login:March 23, 2023, 04:14:26 am
« on: September 25, 2011, 04:33:59 pm »
Hi guys, i running a crt scart hack a the mo.... having a few probs getting it set up right.... i've just got a arcade monitor of a friend which uses a jamma plug for the video signal..... can i use this with my avga.... i using a ipaq at the mo because of the number of buttons i have on the cab..... my cab isn't jamma...
can i make a cable like my vga to scart? but vga to jamma.... sorry for the newbie questions.......
the monitor i have is a eurocoin kth-f..... (samsung tube) but i can't find a thing on it!!!
thx
jahilton2002
Re: avga 3000 to jamma monitor
« Reply #1 on: October 02, 2011, 12:11:20 pm »
hi guys i've had a search but i can't seem to find the answer.
i have a vga 3000 and have got a 6 pin jamma monitor..... i want to make a vga to 6 pin jamma cable....
does anybody have a link the explain how to do this.... is it even possable
thx again
BobA
  • What Me Worry?
« Reply #2 on: October 04, 2011, 10:15:13 am »
From Ultimarc's site:
Info on how to make the vga breakout cable about half way down the page.
Link to cable
« Reply #3 on: October 04, 2011, 02:21:26 pm »
If you've got some terminal pin crimpers and some patience, it's not too hard to make your own. I've made several myself. The most frustrating thing about making your own is that there is no standard for VGA wiring. From one to another, they use different colors, and sizes of wire and handle grounding and shielding differently. The most time consuming part of the process is identifying which wire is which. If you're not able to make your own, Ultimarc sells them for $12.
These were made for Wells Gardner monitors, but also work with Vision Pros.
« Last Edit: October 04, 2011, 02:26:13 pm by Nephasth »
jahilton2002
« Reply #4 on: October 08, 2011, 07:18:04 am »
thx guys :D
