Author Topic: Long time reader, first time builder: MAME Slim Cab  (Read 38493 times)
ambush
  • Last login:February 11, 2013, 08:55:29 am
« on: September 23, 2011, 12:26:32 am »
I've been reading the forums for over a year and finally am getting off my butt to build my own cab. My goal is to finish by Thanksgiving of this year. I have finished a draft of the design I want to follow and made a prototype out of cardboard (see photos). I would love input from this community about pitfalls with my design before I start cutting.
I've taken inspiration from many cabs in the forum, including Knievel's Woody Cab (http://forum.arcadecontrols.com/index.php?topic=55789.0;all), gajaman's slimline cabs (http://forum.arcadecontrols.com/index.php?topic=89163.0), martoon x's Defender cab (http://forum.arcadecontrols.com/index.php?topic=90099.0;all), and others.
Overview on the project
As a big Mortal Kombat fan, I was originally planning to make a Midway clone cab. But after mapping out masking tape to the dimensions of that cab, I realized quickly that it would be much too big for the room I want to put it in. So I decided to pursue a "slim cab" design. Looking at Knievel and others, I created a design in Sketchup. Here it is:
I then built a cardboard prototype to see how it would feel fully built, and I like it!
Here's me looking like a goofball standing next to it.
Design
Here is the design broken down into steps from Sketchup.
First, the base is constructed of 2x4s and a piece of 3/4" plywood on top.
I use an additional 2x4 trimmed and installed at a 45 degree angle to support casters that will be used to move the cab when it is tilted back at an angle. Here is a view from the bottom of the base. (I have a question about the stability of this caster design)
Next, the left side is added to the base.
And then I add in cleats or furring strips along the side. Note that I would install these before attaching to the base, but I am just showing the build up steps incrementally in Sketchup. (I'm curious if it is better to use partial furring strips or full length. I'd like to keep the weight down as much as possible.)
Next I add the interior panels. This includes the monitor mount and an admin panel like Knievel had in his Woody Cab.
Next is the keyboard tray. This will be attached with sliders.
Now I add the exterior panels, including the top, speaker panel, and back. Here is a side view.
And here is a view from the back. The small panel in the upper back is meant to have a hinge on it and be a door so I can access the monitor cables if necessary. Note also that there are cutouts for the casters.
Now I add the door on the bottom front. This will be attached with a piano hinge and magnetic door latch.
Next is the control panel. I've chosen a size that nicely fits 2-player controls + a trackball for Golden Tee and spinner or 4-way joystick.
I'm hoping to do something similar to Knievel's CP layout.
Finally I add the right side and the monitor (LCD 19") and it is complete!
Questions
I'd love advice and feedback from this forum on any aspects of the design, and I also have a few questions:
1- Does the design seem stable? Any concern it would tip over?
2- Should I use partial furring strips (as shown in the design) or full strips top to bottom?
3- Does the caster design seem feasible? They are positioned at a 45 degree angle on the base.
4- Is there some way to make the control panel removable? I'm thinking about some kind of sliding lock mechanism on the bottom of the CP.
5- Paint or vinyl?
6- Any advice on joining?
ambush
Donkbaca
    • Slim built MAME/Xbox cab
Re: Long time reader, first time builder: MAME Slim Cab
« Reply #1 on: September 23, 2011, 01:29:13 am »
I built a slim cab, check out my sig. (man I need to update the pictures of the completed project.)
My thoughts:
1- it's plenty stable, just make sure it's wide enough to fit you pc in the way you want.
2- I used 1x2 batting. Doesn't matter ful or partial, just glue and screw and you will be fine
3-casters- design seems fine, but I would ditch it all together, unless you plan on moving it around a lot.
4- yes, most common way is control panel latches. I got some, but in the end used washers thumb screws and wing nuts along with l brackets
5- depends on what look you are going for. I lean towards paint, but really for no reason
6- simple butt joints, glue and screw, counter sink the screws, putty over and sand flat.
Other observations
1- put a couple vent holes in the back bottom for airflow to the pc
2- don't use a piano hinge in the front door, use hidden euro hinges, it will look better
3- ditch the keyboard drawer , it adds complexity with not much benefit. I would just PKU a mouse and keyboard into the pc to set it up and leave them ther. Once the machine is set up you should rarely , if ever need a keyboard, and having a keyboard out is just asking for trouble from guests screwing around
4 - 19 inch monitor is an okay siR. But it's still pretty small, I would ditch the trackball to save space on the CP. Nothing looks crappier than a huge bezel around the monitor. I have a 21.3 inch monitor, the screen is 17 inches wide, the internal width of my cab us 24 in. giving me a 3.5 in. Bezel on each side. I would not want a bezel bigger than this . Keep that in mind. You don't want a huge bezel it a beefy overhang on your cp box. It won't look right.
Good luck!
quintinbiker
  • Last login:September 27, 2012, 12:47:18 am
  • Go big or go home
« Reply #2 on: September 23, 2011, 04:03:19 am »
Good luck with your build :D
Life is your game
How you win determines your score
How you loose determines your credits
But to play the game you have to have real credits.
That's why I'm
GAME OVER
LIVE TO RIDE
RIDE TO LIVE
Biker born, Biker Bread, When I Die I'm Biker Dead
TopJimmyCooks
« Reply #3 on: September 23, 2011, 09:33:13 am »
Looks very familiar :laugh:
I did a similar thing with the casters, but smaller and more recessed.  make sure to get the fixed casters rather than the swivels, and make sure they're rated for 200lbs or so.
They're better than nothing but i give them about a 5 out of 10.  I grab the hand truck or just shove it around for the most part.  They barely touch the floor when level, all the weight is on the base.  so, to get them to roll, you have to tilt the cab back about 30 degrees, and the weight wants to get away from you.
Fully agree with Donk's inputs:  I am going to go back and add low ventilation intakes as everythings running pretty hot in there even with a top exhaust fan.
the pix are behind the build but take a look at my threads below.  I have an evo style cab with knievel style cp and a 19" monitor.  I can send you some completed cab pix, just haven't posted them yet.
« Reply #4 on: September 23, 2011, 11:57:26 am »
The only thing I would add about the casters is that they seem to be really big or far back. If you butt it up against a wall, it looks like there would be a big gap there due to the wheels. Maybe it's just the way the model looks.
ambush
« Reply #5 on: September 23, 2011, 12:16:16 pm »
My thoughts:
Other observations
Good luck!
@Donkbaca, thanks for your input! Very helpful.
You've convinced me to drop the casters. I'm not going to be moving this regularly. In fact, I'll probably earthquake strap it to the wall.
On the monitor size, what is the ideal size and aspect ratio for an LCD monitor? To keep this slim, I don't want to use a CRT or TV.
ambush
« Reply #6 on: September 23, 2011, 12:22:35 pm »
@TopJimmyCooks that does look very familiar! I read your posts. Very cool.
Why did you decide to use MDF for the sides and plywood for the CP? Isn't MDF heavier?
I see you're using a 19" LCD monitor too. Does that feel too small like Donkbaca suggested?
You've further convinced me to not use casters. But I will add ventilation. Would you recommend installing a ventilation fan inside?
ambush
« Reply #7 on: September 23, 2011, 12:23:04 pm »
Donkbaca
« Reply #8 on: September 23, 2011, 12:55:58 pm »
Its not that 19 inches is too small, its just be mindful of the monitor size when building, because a large bezel always looks bad, if you are using a 19 incher, just make sure you make the cab narrow, I wouldn't want a bezel of more than 2 inches or so on the sides.
If you look at my build, I have a 21.3 inch 4:3.  That's the biggest 4:3 lcd you can get, and they are all mostly very, very good screens.  I believe Kneivel used a 20 inch in his builds.
I would suggest smoked plexi for the front too.  The bezel was a pain in the ass and a half to get right, and the smoked plexi helps hide a lot of imperfections, and looks cool when the cab is off.
TopJimmyCooks
« Reply #9 on: September 23, 2011, 02:30:51 pm »
My 19" was a gift from my brother and was going to be the display from the beginning.  However, the monitor auto rotates from Horizontal to vertical, so I'm using the full screen area for gameplay both ways.  To allow room for the monitor to rotate, it is 24 1/8" wide inside the sides.  When the CP is in it's smallest configuration, it's box is the same width as the cab.  In a perfect world, I would choose the the 21" 4:3 LCD - those were great.  I would't want to go any bigger if you like vertical shooters, with the controls where they are its the biggest screen I can take in.
I used scraps I had around for the cp which were mostly plywood, and structural rigidity was more of a concern there with the moving parts.  the cab I made from MDF because I was planning to paint it and wanted the smooth, flat substrate.  Also, the shop grade ply I like to use costs a lot more and I've been trying to keep the costs in proportion.  It is heavy as ****, hence the wheels.  As I said, my wheels are really too small.
There have been many cabs lately with this design and it's proved a good one.  Arcade looks, suited to lcd display depth, scales nicely to different widths.  I would love to see someone do a narrow vertical one like a Toobin' cab.
jimfath
  • Last login:April 20, 2021, 02:58:31 am
  • IT consultant
« Reply #10 on: September 27, 2011, 03:45:50 am »
Looks like a really cool build. I'm actually glad I found this as I'm working on something similar myself.
As these slim designs go, I've heard of people either anchoring them to the wall and/or putting weight in the base. Your plans seem to be deep enough. If it's going to reside on soft carpet and it's center of gravity is higher you might run into some issues. Hard to say. You'll know once you get it put together.
I like this idea and have seen it used in other builds. I plan on using it myself. I move a lot and my wife likes to rearrange the furniture quite a bit. The wheels do look like they might affect how flush the machine is against the wall. Topjimmy's are a little more recessed.
I'm leaning towards some sort of cabinet latch. I know GGG sells them or at least they used to. Someone used a pair of monitor brackets to hold up the panel. I can't remember which build though.
Good Luck in the build brother!
@jimfath
ambush
« Reply #11 on: September 29, 2011, 12:56:24 am »
@jimfath thanks very much for the ideas! I think I will anchor it to the wall as I have a little boy in the house and don't want it to topple over.
Do you have a link to the GGG cabinet latch? Would love to check that out.
Thanks!!
ambush
« Reply #12 on: September 29, 2011, 10:45:11 am »
@Donkbaca  does the smoke plexi make it harder to see the screen? Do you have a link to the product?
Thanks.
ambush
« Reply #13 on: September 29, 2011, 11:07:56 am »
I added a mockup of the Bezel to see how bad it looks and I see your point. It's big.
The issue is that I'm hesitant to reduce the width of the cab in case I ever want to upgrade the monitor. But maybe that is not a smart strategy?
I'm also hesitant to reduce the width of the cab because I don't want to reduce the width of the CP.
Alternatively, I was thinking I could use the extra bezel area as a place to have game codes, like the MK bezel below. It would be cool to have different bezel overlays that could be attached based on what game is being played.
Other ideas?
TopJimmyCooks
« Reply #14 on: September 29, 2011, 11:25:51 am »
your pic is basically what my 19" looks like.  the bezel is 4" on the sides, 6" on the top/bottom, and the reverse when rotated.  It doesn't bother me but I would def. desire to go bigger for horizontal only.  I would go with 24" width on the cab, looks proportional and it's easy to upsize the display at any time.
I used 1/4" gray tinted glass, 30% light transmission.  You really can't tell much if any difference on the screen, even when you AB compare it.  I may have bumped the brightness up a few clicks.  Mine is back painted black to create the bezel area.  glass shops will give you samples to take home and look at.
Donkbaca
« Reply #15 on: September 29, 2011, 11:37:48 am »
OK a few things:
 - I wouldn't worry about upgrading the screen, In my mind, the biggest pain was cutting the bezel ,just build it more narrow
-alternatively you can try and get a 21.3 inch screen.  You can find used ones on ebay for under $200.  If you get one in good condition, they are totally worth it as a lot of these are top of the line ones that sell for $500+ new
I just used plain plexi and grabbed window tint and applied it myself.  I know that people on here have bought smoked plexi online before.
Applying it yourself kind of sucks, you need to be patient and do it in the most dust free place you can find.  Its pretty cheap though, and looks really good.  You can't see anything when the monitor is off, the whole screen area is black.  I also used the tint on my marquee since Its edge lit etched plexi.  I need to upload pictures, maybe tonight, if I have the chance
Whatever you do, just be mindful of proportion, and remember the number one rule, build the cab around the monitor!
jimfath
  • IT consultant
« Reply #16 on: September 29, 2011, 10:56:43 pm »
Thanks!!
This is the control panel latch they sell at GGG. It's pretty basic and you can find versions of it at your local hardware... BUt if you were ordering other stuff from GGG you might want to take a look.
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=70&products_id=204
« Last Edit: September 30, 2011, 05:55:09 am by jimfath »
@jimfath
ambush
« Reply #17 on: October 01, 2011, 11:50:38 pm »
I'm trying to decide what type of speakers to use. Do you guys recommend car audio? PC speakers? or something else?
The speaker panel I have is 6 21/32". So the speakers could be 4" in diameter or width.
Mister Hat
  • Last login:April 12, 2013, 10:05:59 pm
« Reply #18 on: October 02, 2011, 01:22:09 am »
You can buy car stereo speakers (you can find them pretty cheap) and hook them up to an old PC speaker interface or just buy an amplifier online for about $10-15.
By the way, I really like the looks of your project so far. Keep it up.
ambush
« Reply #19 on: October 04, 2011, 02:13:54 am »
Thanks @Mister Hat. Good suggestion. I think I'll go for 4" diameter car speakers and see how they work out.
ambush
« Reply #20 on: October 04, 2011, 02:39:49 am »
Status update and plans update....
I spent some time this weekend going over the plans with a friend who is going to help me build the cabinet. He has the tools and woodworking experience. After we came up with a plan, we left to buy wood and ... bummer ... the lumberyard was closed. So, cutting is delayed one more week and should start this next weekend.
This has given me some time to refine the plans based on the feedback from this forum and my friend's ideas. First, some conclusions:
1. No casters. What's the point? I'm not going to move the cabinet much. I will add levelers.
2. I'm going to stick with the width of the cabinet and the 19" monitor. I'm not going to build a rotating motor. This is my first cab so I want to build something I know will look good and be sturdy. To overcome the issue of a bezel that is too big, I'm going to look into some artwork that can be placed on the bezel as a cool effect.
3. I've replaced my spaced out 1"x2" furring strips with full vertical 2"x2" furring strips. This will make it a lot easier to assemble, will help with screwing without splitting, and shouldn't add too much weight.
4. I'm going to build the whole thing out of 3/4" AC sanded plywood. This will be a nice surface to paint. Using all 3/4" will be heavier than optimizing with some 1/2" but will be simpler to cut and build.
5. I like the idea of smoked plexi for the bezel. Going to see how that looks.
6. Added vent holes up and down the back of the cabinet. Will add some mesh to cover the vents.
7. Will make the control panel removable, either with latches or bolts and nuts.
8. I'm going to keep the keyboard tray for now but may lose it later.
Need some links / advice:
1. Levelers?
2. Control panel wiring: I've read doorbell wiring, ethernet cables and other electrical wiring
3. Gotchas in using car audio speakers
4. Wire/metal mesh to cover air vents
5. Primer and paint - what type?
6. Euro hinge link?
7. I need some kind of flexible rubber piece to go between the admin panel and control panel. There is a small gap there and the control panel lid will hinge open.
8. Marquee mount?
9. Other things I'm forgetting?
Still to do:
* Map out the control panel
* Design the artwork
Here are updated design pics.
Base frame (2"x4"s)
Base with plywood top
Left side with furring strips attached
Left side attached to base
Both sides attached to base
Interior (monitor mount, speaker panel and admin panel) attached to sides
Rear view of interior attached to sides
Exterior attached to sides and base, with vent holes
Rear view of exterior. Note the upper panel will be hinged so that I can access the monitor from the back
Keyboard tray attached to sides (non-structural)
Door attached to sides using Euro hinge and magnet lock (non-structural)
Control panel box (top view)
Control panel box (side view)
Control panel with lid (side view)
Control panel attached to cabinet
Monitor attached to cabinet
Bezel attached to monitor mount
TopJimmyCooks
« Reply #21 on: October 04, 2011, 11:24:02 am »
I would leave a toe kick area at the front.  Are you going coin door or making the front open like a door?  Also, consider rounding off the back corner of the sides at the bottom, or life will round it off for you.
It is quite nice to be able to access the pc from the front, reduces moving the thing around a lot.  I did not follow my own advice on this.
Donkbaca
« Reply #22 on: October 04, 2011, 11:29:26 am »
I would reconsider the width of the cab.  Artwork around the monitor only accentuates teh bezel, IMHO.  It makes the whole thing look too busy.  I think the solution probably would be to put smoked plexi across the whole front, which will hide the whole thing when its off.  Probably will look the best and be the least amount of work.
Make sure your wood is flat!  I keep bringing this up because the sheet I used for my CP wasn't and that created issues.  Take your time in picking out the wood.
1. Levelers? - What is it going to be resting on?  If a hard floor, I say it may be a good idea, though your floors should be level.  If its on carpet, I don't think its that necessary
2. Control panel wiring: I've read doorbell wiring, ethernet cables and other electrical wiring - Use anything you want.  just get something that is 18-22 gauge since that is the most common size for disconnects.  Stranded wire is easier to work with, solid is neater.
3. Gotchas in using car audio speakers - Can't help you there.  I am using multimedia speakers
4. Wire/metal mesh to cover air vents - I used speaker cloth
5. Primer and paint - what type? - can't help you, stained my cab.
6. Euro hinge link? I have some that I use for the panel under my CP where my xbox 360 is.  I just got them at home depot. they have  a selection of them in the cabinet hardware section
7. I need some kind of flexible rubber piece to go between the admin panel and control panel. There is a small gap there and the control panel lid will hinge open.  - I htought this too, but if you position the top of your panel right, and your wood is straight, the t-molding will cover the gap.
8. Marquee mount? - I built my own out of wood. but then again, my marquee is different since it is edge lit plexi
9. Other things I'm forgetting? - Seems good to me, as long as you have wood, tools, t-molding, controls, and wiring, you should be good
eds1275
  • Last login:October 06, 2025, 04:35:27 pm
  • Rock and Roll!
« Reply #23 on: October 04, 2011, 03:32:14 pm »
What I ended up doing on my cab is drilling pilot holes through some hockey pucks, then bolting them to the 2x4 base. After that I stuck some 3" circular furniture pads on the bottom - this thing slides around no problem on a smooth floor like laminate or linoleum, but is sturdy enough to stay in place when playing. Check out the bottom of my cab, you can see one of the pucks!
I wouldn't suggest doing this on carpet though.
ambush
« Reply #24 on: October 11, 2011, 12:20:37 am »
First cuts on the cabinet complete.
Shopping list:
* (3) AC sanded superply from Dunn Lumber
* (3) 2x2x8 douglas fir furring strips
* (1) 2x4x10 douglas fir
* bearing guided clone router bit
* 1/16" slot cutter router bit
* (1) box 1.5" wood screws
Photos:
Here is the AC Sanded Superply board. It is super smooth on one side and okay smooth on the other.
First we ripped the board to the dimensions 20" x 72.5" and placed it on sawhorses.
Here I am measuring and drawing the design on the board with a pencil. I used that glass jar for the rounded corners.
We started making cuts with the circular saw, cutting all of the straight areas we could. We used the jigsaw to tackle some of the curves.
Some of the curves didn't work that well. Oh well, we'll sand it up.
Here's the first side complete.
Then we clamped the first side onto the second board and used a clone router to get an exact match.
Close up!
Completed cloning. (except for that 90 degree angle, we fixed that with a handsaw)
This cloning bit takes out about an inch of wood and makes a lot of dust!
And we're done! Two identical, yet mirrored sides.
Overall, this took a long time to get perfect, but probably worth it.
We also cut some of the furring strips but did not cut the other panels yet.
More to come ...
TopJimmyCooks
« Reply #25 on: October 11, 2011, 10:16:47 am »
Next time consider using the first side to trace the second side with a pencil.  then, cut to about 1/4" outside the line with jigsaw, circular saw, etc.  Then clamp and pattern rout.  The smaller, open cut will help your bit run cooler, cut better and last longer than if you cut the full width of the router bit.   good looking work, keep going!  :cheers: TJC.
ambush
« Reply #26 on: October 13, 2011, 03:54:14 am »
Good suggestion. Thanks TJC.
ambush
« Reply #27 on: October 13, 2011, 04:15:05 am »
I spent a while researching and designing the control panel tonight.
Here is a pic of the design. I would like feedback!
Direct link: http://i53.tinypic.com/17rgjr.png
Panel width: 34"
Panel height: 13 1/4" at edges and 14" in center
Motivations:
* I have a 28-input legacy i-pac interface that I'm hoping to use
* 7-button design supports fighters including all in the Mortal Kombat franchise (Run button in the traditional place)
* Ergonomic friendly layout of player 1 and player 2 buttons (from slagcoin.com)
* 3" trackball for Golden Tee + soft-mapped Golden Tee buttons in as close to traditional placement as possible
* Spinner + 8th button for each player placed above for spinner games
* Explicit coin and start buttons
* Implicit mouse buttons (for use with trackball)
* Soft-mapped B and A buttons for classic arcade titles like TMNT and Mario
Questions:
1. Can I achieve what I have mapped out? Specifically,
  a) can I soft-map the Golden Tee buttons across the panel like that?
  b) can I wire and map the mouse buttons to existing CP buttons? I'm looking at either the Happ 3" USB trackball (http://na.suzohapp.com/trackballs/565600xx2.htm) or the Groovy-TB Arcade Trackball (http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=74&products_id=363)
  c) can I soft-map the B and A buttons for classic games? Is this a game by game configuration?
2. Is there enough spacing on the panel for comfortable play?
eds1275
  • Rock and Roll!
« Reply #28 on: October 13, 2011, 06:14:59 pm »
What you can do is wire 2 microswitches to 1 input. Just connect the grounds together and the no's together, and then either one works for an input. It could of course be a pain if someone reaches up and presses the daisy chained buttons in the middle of a fighter game or something.
ambush
MAME Slim Cab - first cuts, CP designed, now onto second cuts
« Reply #29 on: October 14, 2011, 11:16:41 pm »
First cuts are complete.
CP is designed.
Now onto the second cuts. Once again, turn to Sketchup to figure out how to best use the plywood we have remaining.
Direct link: https://lh4.googleusercontent.com/-4YrxaBMXqcw/Tpj2GVW26aI/AAAAAAAAD7I/uxOIrqytARQ/s0/Cut%252520List.png
We have decided to use the 3/4" plywood for all surfaces. Originally, I was thinking about using 1/2" for the control panel, but I don't expect 3/4" to add too much weight, and it's easier to deal with consistent lumber.
Still looking forward to feedback on the Control Panel design. Any thoughts?  :burgerking:
ambush
MAME Slim Cab - first assembly!
« Reply #30 on: October 17, 2011, 12:40:13 am »
We made a ton of progress today and now have an assembled upright cab.
First, we cut all of the various pieces on the table saw.
And cut the 2x4's for the base.
And constructed the base, using deck screws.
Wow, I look happy for a simple task.
We decided to use the nail gun, which was a genius move and made things go much faster. We are using 2.5" nails to attach the base board to the 2x4s.
Completed base with board.
Next, we mapped out the 2x2 furring strips and countersunk those from the inside out. Thanks to Blanka for the suggestion to work from the inside. It saved us a ton of time. We used 2" screws and a countersink bit to embed the screws an 1/8" into the 2x2s.
Here's the first completed side
Then we did the other side and amazingly the furring strips lined up exactly!
Here's my new idea for an iPhone cab.
Next, we attached the base, again by countersinking from the inside using 3" deck screws.
Then we attached the lower back panel and clamped it all together to hold it tight.
We stood it up and it was sturdy!
Then we added the top panel to set the width of the cab.
And we used the nail gun to attach two back panels and the top panel.
We cut the top panel at a 39 degree angle on the table saw to fit the curve of the back of the cab.
And here's the final product for today.
@Donkbaca, I wanted to mention that I considered shrinking the width of the cab, but after adding my computer in Sketchup, I realized that I couldn't gain enough to make a difference. Thanks for the suggestion though.
Next up....
1. Buy lots of parts: speakers, LED, CP buttons and joysticks, plexi, hinges, primer, paint.
2. Finalize and cut the CP. Here is the current design. Direct link: http://i53.tinypic.com/17rgjr.png
3. Cut holes and install fans, electrical out and speakers.
4. Prime, paint.
5. Design artwork and order prints.
6. Wire it up.
What do you think?
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #31 on: October 17, 2011, 05:47:27 am »
As for speakers, someone posted this somewhere:
http://www.amazon.com/Sure-2x15W-TA2024-Class-D-Amplifier/dp/B003XRNRB6/ref=sr_1_1?s=electronics&ie=UTF8&qid=1318579848&sr=1-1
You can probably power it via a harddrive molex off the computer power supply.
Looks like you could probably fit a pair of 6x9's?
http://www.amazon.com/Kicker-07DS6930-6-Inch-9-Inch-Speaker/dp/B000YPRWZW/ref=sr_1_56?s=electronics&ie=UTF8&qid=1318844742&sr=1-56
ambush
« Reply #32 on: October 17, 2011, 10:45:23 am »
@cotmm68030, thanks for the links!
Based on my design, the max size I could go with speaker cutouts are 4x4 or 4x6. Looks like this same model is available in those sizes, but cuts out some mid range. Would I need a subwoofer?
Also, is there concern about these speakers not being magnetically shielded and being so close to the monitor?
Donkbaca
« Reply #33 on: October 17, 2011, 12:41:15 pm »
Looks good.
As for speakers - just get computer speakers.  I would get a cheap 2.1 system.  The one I have in my cab has the volume and bass controls on the sub, so no volume pots to mess with on the speakers, I adjust all the volume through software on a game by game basis.
 Remember the original cabs didn't have fancy speaker systems in them, and a lot of older cabs don't even have stereo sound.  A cheap sub enclosed in the cab really makes everything sound good.  With a 2.1 computer speaker system, you are looking at like 40 bucks or less, and its easy to set up, you just plug and play, no worying about amps and volume pots or any of that stuff
ambush
« Reply #34 on: October 17, 2011, 01:00:59 pm »
I'm thinking about buying the following from CoolerGuys. Is this overkill?
The idea is to have a dual 120mm outtake fan in the back upper part of the cabinet, and a single 120mm fan in the back lower part of the cabinet. All will be controlled by a temperature trigger with LED display.
Fan Cooling Kit for upper part of cabinet, 2 fans, LED control http://www.coolerguys.com/840556086352.html $89.95
Single fan for blowing air in at base http://www.coolerguys.com/840556093640.html $23.95
3-pin sleeved extension cable 72” http://www.coolerguys.com/3pnslext.html $2.79
3-pin Y cable http://www.coolerguys.com/840556088752.html $1.95
newmanfamilyvlogs
« Reply #35 on: October 17, 2011, 01:19:21 pm »
that's probably quite overkill. there was a thread not too long ago about cab ventilation, and in several pages no one claimed failure based on heat.
I've got a AMD Athlon II system with a GTX 260 video card in a small unventilated cabinet that occasionally gets left on and forgotten about. In the most recent instance, running Portal 2 unattended for two days. The metal case was almost too hot to touch, yet still it ran.
Cut some ventilation slots at the top, cover them with speaker cloth, and let convection draw the hot air up like a chimney.
newmanfamilyvlogs
« Reply #36 on: October 17, 2011, 01:25:46 pm »
http://www.amazon.com/Kicker-11KS46-4-ohm-2-way-Speakers/dp/B004ZH291C
Perfectly matched to that little 25w amp. Remember that the whole cabinet is going to act like a resonance chamber for the speakers, so it should really fill the sound out. These will almost certainly sound better than a cheap set of PC speakers. A subwoofer will probably take up more space in your cabinet than would be worth to include.
As for magnetic sheilding; LCDs are unaffected, so it doesn't matter.
EvilNuff
« Reply #37 on: October 17, 2011, 09:44:35 pm »
1. Levelers?
6. Euro hinge link?
8. Marquee mount?
1. Check and see if you have a woodworking store in your area.  Woodcraft or Rockler, alternately you can order from either of those online.  They will have furniture levelers rated for whatever weight you want.
2. Any of those work, doesn't really matter much.
3. Easier to just use pc speakers IMO.
4. Any pc supply/parts store should have wire/mesh brackets for pc case exhaust, you could use those over a hole in the back of the case easily.
6. See #1 :)
9. Looking good so far! :)
ambush
« Reply #38 on: October 18, 2011, 07:55:12 pm »
First design of the artwork for the control panel is done.
Here is the design with graphics for the various buttons and joysticks. I decided to go with simple colors - all player joysticks and buttons are black. Coins are green. Spinner buttons are blue. P1 and P2 start are white. This lets the art do the talking.
Direct link: https://lh4.googleusercontent.com/-ziyn5cbRXBQ/Tp4QwxHCENI/AAAAAAAAEAk/WBgX8a_xVUg/s0/CP-art-design-2011-10-18-3.png
And here is what it would look like to print:
Direct link: https://lh4.googleusercontent.com/-K_LCHbigtBM/Tp4QxAxtKlI/AAAAAAAAEAo/okwrI6l3mkg/s0/CP-art-design-2011-10-18-3-print.png
I like the general concept of "chaos" that comes across with all of the characters up to something.
Thoughts? Feedback?
newmanfamilyvlogs
« Reply #39 on: October 19, 2011, 05:43:11 am »
I don't think it's dense enough to convey a sense of 'chaos'. To me it looks unfinished.
For a chaotic feeling, i would have every inch of the panel covered in overlapping characters. Usually the general rule is to not mix arcade and console characters together, and also not mix in-game vs comic book representations of characters, but in this instance it might work well enough. None the less, I don't think we should be seeing any blue in there.
Here's a fun idea-- get a bunch of sprite-sheets from various games, crop them down to one image per file (many files), then use them in a photomosaic program to generate an arrangement of characters that resembles something from a distance. That would definitely fit an 'order from chaos' theme.
