Author Topic: Cheap wired 360/PC controllers... under $11 at Amazon  (Read 2180 times)
Well Fed Games
  • Delicious!
shateredsoul1979
  • Last login:December 22, 2011, 01:09:28 pm
Re: Cheap wired 360/PC controllers... under $11 at Amazon
« Reply #1 on: September 23, 2011, 01:05:23 am »
Man that's an ugly controller
« Reply #2 on: September 23, 2011, 02:48:33 am »
Anybody know if they are easily hackable?
Most Madcatz controllers are. But I say you be the guinea-pig. I'd do it myself, but amazon.com doesn't sell to Canadians.  In other words....NOT IT! :D
Well Fed Games
  • Delicious!
« Reply #3 on: September 23, 2011, 09:05:28 am »
Yes, I can see why they are so cheap!!!
Picked up two, I am not an expert but will try to post a pic of the PCB when I get them next week.
« Reply #4 on: September 23, 2011, 09:41:21 am »
Good luck.  Hacking the triggers on those things SUCK.  There's a reason I don't touch them anymore.
Well Fed Games
  • Delicious!
« Reply #5 on: September 23, 2011, 10:07:32 am »
I was thinking, in the project I would like to use them for, I only need 10 inputs per player (2 8way joys, start, coin), so with d-pad, face buttons, and start/back, I should be ok.... As far as hacking them, can I just ignore the triggers entirely or will they still be a problem?
Good to know that folks should pass if they have plans for the triggers!  :cheers:
If nothing else I will have a couple cheap (if extraordinarily ugly) pads for PC gaming...
« Reply #6 on: September 23, 2011, 10:19:49 am »
Oh yeah, you can ignore the triggers, no problem.
All the other stuff, including RB and LB, are easy to hack.  It's just the triggers that are a PITA.
Well Fed Games
  • Delicious!
« Reply #7 on: September 23, 2011, 10:21:56 am »
Sweet! Thanks for the info! :applaud:
