Poll
Which way do you turn a monitor for "officail" tate?
CW
0 (0%)
CCW
2 (100%)
Total Members Voted: 2
Author Topic: "official" direction to turn for tate/ vertical monitor?  (Read 3651 times)
sharpfork
    • KADE
« on: September 20, 2011, 01:30:12 pm »
In searching around her and the interwebs, I've seen that vertical monitor orientation/ Tate generally is a CCW rotation so the bottom of the monitor ends up on the right side.  I have seen a few rotating monitor videos what have it turn the other way.
It there an "official" or recommended direction to rotate a monitor?  I'm going to be using mostly MAME so it might not really matter but I'd like to do it the correct way in case I decide to use a Jamma board at some point.
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
Re: "official" direction to turn for tate/ vertical monitor?
« Reply #1 on: September 20, 2011, 04:32:37 pm »
there are a couple of console games which only offer tate left ( ccw ) . arcade cabinets can flip the screen 180 deg if needed . i own a cabinet which rotates clockwise and the tube is mounted with the anode plug on the bottom .
sharpfork
    • KADE
« Reply #2 on: September 20, 2011, 07:46:08 pm »
Thanks for the info.  So If I revert my cab back to a JAMMA board with a tate game, I should be able to rotate the pic either way?
I came across one of those console games (Raiden II PSX) that does tate left/ CCW.  I mounted my tate cab right/CW and now I'm wondering if I did it wrong.  I can get most other emus to show the picture correctly so it hasn't been an issue.  I have a somewhat MacGyver ish monitor mount and don't really want to pull it...
TopJimmyCooks
« Reply #3 on: September 20, 2011, 08:46:19 pm »
I realize you guys are talking Jamma/arcade monitor.  Just to note for LCD 'tater purposes, check the viewing angle.  some lcd's have a bad angle to the bottom and so do best rotating counter clockwise to give the best view to P1.  iSharpfork, f you rotate an arcade monitor, post it up, love to see those done.
sharpfork
    • KADE
« Reply #4 on: September 21, 2011, 10:28:03 pm »
iSharpfork, if you rotate an arcade monitor, post it up, love to see those done.
I have my centipede tate at the moment with a 480i TV.   If you flip through the album, you can see how I wimped out pon a complete de-casing:
http://sharpfork.imgur.com/ramp#y4Z7E
I also have a Dynamo cabinet that still has the JAMMA harness so I'm researching options.  The Dynamo is super easy to rotate the monitor in.
