Author Topic: cutting for a t-mold?  (Read 1727 times)
davellaman
  • Last login:September 29, 2003, 11:11:58 pm
« on: September 11, 2003, 10:23:35 pm »
What tool is used to cut for a t-mold?
Thanks,
Mark
Sasquatch!
  • Last login:March 01, 2010, 04:11:47 pm
  • Toot-Toot!
    • Arcade Paradise
Re:cutting for a t-mold?
« Reply #1 on: September 11, 2003, 10:27:27 pm »
Router with a 1/16" slot cutting bit.
Cisco Kid
« Reply #2 on: September 12, 2003, 01:10:11 am »
To be more exact (in case you don't know what to buy or where to get it)
- 1/16" Three Wing Slot Cutter -
http://freud-tools.com/freud56threw.html (item # : 56-100)
- 1/2" Shank Slot Cutting Arbor -
http://freud-tools.com/freud60slotc3.html (item # : 60-122)
... and of course you need a router that accepts a 1/2" shank ... and you'll be ready to start cutting those slots for your T-Molding  ;D
Hope that helps ya
pointdablame
« Reply #3 on: September 12, 2003, 10:56:51 am »
are there any bits for a 1/4" shank? I found a good deal on a 1/4" router at Home Depot and was gonna get that, but not if I can't use it for the main reason I'm buying it for.
first off your and idiot
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #4 on: September 12, 2003, 11:07:48 am »
Next I'll be on fries, and that's when the big money starts rolling in.
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #5 on: September 13, 2003, 12:37:13 am »
I got mine from MLCS Woodworking.  $16 for the whole assembly, and it works like s champ.
davellaman
« Reply #6 on: September 16, 2003, 01:43:24 pm »
will any of these work?  These are from home depot.  I was also looking at the router add on for the dremel since I currently own a dremel and not a router.  Any ideas and thoughts on this would be greatly appreciated.
Router Accessories
  Name Price Qty. Add to Cart
  1/8 In. Radius Rounding Over Bit
« Last Edit: September 16, 2003, 01:45:08 pm by davellaman »
Radical
  • Last login:March 12, 2022, 03:39:21 pm
  • Yes
« Reply #7 on: September 16, 2003, 02:59:58 pm »
I don't think any of those are what you're looking for.  You need a slot cutting bit.  Take a look at some of the links posted above.  They got pictures and everything.
When I was in Lowes the other day I saw one but I don't know if they had the right size.  I haven't looked at Home Depot.  Neither one lists it on their website (both their websites suck IMO).
I can't say I've tried the Dremel but it seems like a lot of work with that little tool.  I would think it might be difficult to keep it flat on the surface while cutting.
