Author Topic: No Red on a Neo-TEC 2701  (Read 1427 times)
NightWolfx03
  • Last login:March 05, 2024, 04:58:44 pm
  • NoctemLupi
« on: September 14, 2011, 11:39:22 am »
What do I need to check if I seem to have an absence of red. The screen almost looks like it's a big blue / green fire.
I don't have a service manual or schematic for this monitor.
I'm the man who's going burn their house down.... with the lemons.
NightWolfx03
  • NoctemLupi
Re: No Red on a Neo-TEC 2701
« Reply #1 on: September 14, 2011, 12:25:36 pm »
Actually I think I spotted a shorted transistor / FET on the neck board. I wonder if it ruined anything else or not. It's looks like a drive transistor, it's emitter and base seem to be shorted.
grantspain
« Reply #2 on: September 14, 2011, 01:33:24 pm »
most common issue when missing colour is the drive transistor
Kevin Mullins
    • Me on Myspace
« Reply #3 on: September 14, 2011, 02:56:43 pm »
Swap transistors from one of the other colors to verify.
Have the tube itself checked too....the Zenith ones that came with those like to crappy color guns.
  • Last login:Today at 04:23:32 pm
« Reply #4 on: September 16, 2011, 05:00:53 pm »
sometimes the video amp chip goes. if swapping the transistors keeps the image the same, it's probably the LM1203N (IC901)
if swapping the transistors yields a red/blue or red/green image, your transistor is dead.
NOTES:
transistors fail in one of two ways:
SHORTED...
if your image is completely bathed in a color, you have a transistor shorted causing the color to stay on 100%. it is not uncommon for 1 transistor to short out and cause a 2nd to short as well. the heat generated from the shorted transistor overheats the next one closest to it.
OPEN...
if your image is simply lacking a color(s) then you have an open transistor. replace it.
NightWolfx03
  • NoctemLupi
« Reply #5 on: September 17, 2011, 12:24:52 pm »
Yeha I pulled the transistor off the board, I have a dead short between the emitter and the base. waiting for the replacement to come, now I need to get the k7000 finished, there's a newer thread about it.
