Author Topic: Perfect 360 Joysticks.. how to connect?  (Read 1565 times)
infariot25
  • Last login:March 13, 2012, 01:16:44 am
    • Nerd Palace
« on: September 10, 2003, 04:44:01 pm »
hey
I finally bought some perfect 360 joysticks.  I am confused on how to hook them up.  I have a PC At style power supply(supplies the correct voltage right?).  How do i connect these to my mame cabinet (x arcade is the control interface)
thanks for the help in advance
Homebrew
  • Last login:May 03, 2012, 09:48:55 pm
Re:Perfect 360 Joysticks.. how to connect?
« Reply #1 on: September 10, 2003, 05:05:38 pm »
you'll need to connect the 5v power wire from the P360 to the red wire on one one of th e4 pin molex connectors.  In case you don't know what connector i'm talking about, there will be about 3 or 4 connectors on the Power supply that are the same.  They should have a yellow wire(12v), 2 black wires(grounds), and 1 red wire(5v).
 As far as the rest of the wires on the joystick, you hook them up just as you would any other joystick(or the joysticks you're replacing?).  Hope this helps.
-Kevin
Hammerbot
  • Last login:September 04, 2005, 10:40:51 am
  • All work and no play...
« Reply #2 on: September 11, 2003, 01:59:49 pm »
Will these even work with a Keyboard Hack?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: September 11, 2003, 02:02:34 pm »
Yeah, you need to get power from a 5v source to the p360, then just wire the rest of the pins to a keyboard hack (yuck).
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #4 on: September 11, 2003, 02:55:15 pm »
hey
I used screws, they worked well.
This opinion was created from 100% post consumed information.
