Author Topic: X-arcade problem  (Read 1870 times)
caskad
  • Last login:April 02, 2012, 02:48:22 am
X-arcade problem
« on: August 30, 2011, 02:29:52 am »
Hello,
i don't know if i'm rgight section but, will ask for help :)
I try to connect (Mars ME111 13 pins, coin door), on buton 7, and i make a "boulette"...
http://www.xgaming.com/support/questions/54/Advanced+BYO+Kit+installation+diagram+with+wiring+schematic.
controller j6 is out.... buttons 3.6.7.8 doesn't respond att all .. :banghead:
it m' not very good, so i test the 4 diode (led in english??) and there are OK with the multimeters (gives me 0.6 , i can't remember  yet..)
Is there a shema or someone who can guide me to correct test this?
cheers
« Last Edit: August 30, 2011, 02:31:56 am by caskad »
BobA
  • What Me Worry?
Re: X-arcade problem
« Reply #1 on: August 30, 2011, 04:57:55 pm »
Your Mars ME111 is powered by 12V.  Your X arcade is 5V.  Depending on what you connected to the X arcade controller you may have blown the inputs on j6.   You did not provide into on what you connected so I am only guessing at this point.
gryhnd
« Reply #2 on: August 31, 2011, 03:05:58 pm »
I just wired my coin door triggers to the buttons on my X-Arcade tank stick that simulate a coin drop.  So when you put in a coin, the circuit completes and it's the same as the button being pressed. Requires no power at all from the door.
After that I did also wire a hidden switch that breaks the button circuit so I can force use of the coin door only.
Very simple wiring.
Completed: No Name Upright
caskad
« Reply #3 on: September 01, 2011, 07:10:21 pm »
Thx for explain,
I've wiring on the fly and make a stupid mistake  :badmood:
controller j6 is out  :banghead:
rebuy one !  :censored:
