Author Topic: key mapping config problem in mame32  (Read 5695 times)
dexterclaire
  • Last login:September 01, 2004, 04:18:49 pm
  • the arcade version is always better.
    • Inner Peace Security
« on: July 08, 2002, 09:05:03 pm »
Hi,
I have a little problem.  The default key to press to access the internal configuration menu in mame32 is TAB, but I 'accidentally' set this to ENTER.  Now I can't select it to change it back because whenever I hit ENTER it makes the menu appear and disappear instead of selecting the item from the menu.  Hrm..  Well, is there some kind of ini file i can edit directly without using the configuration menu so I can set it back to TAB?
- dex
« Last Edit: December 31, 1969, 07:00:00 pm by 1026619200 »
Re: key mapping config problem in mame32
« Reply #1 on: July 09, 2002, 08:52:01 am »
nope, you'll have to delete your default.cfg file and start over
