Author Topic: Radioshack released new converter !  (Read 3264 times)
SNAAAKE
  • -Banned-
« on: September 09, 2003, 07:25:15 pm »
Works Perfectly with digital pad and everything !
only $10.Local radioshack should have em.
part # 26-304
« Last Edit: September 09, 2003, 07:27:15 pm by SNAAAKE »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Radioshack released new converter !
« Reply #1 on: September 09, 2003, 07:30:05 pm »
will it work for DDR pads?  Will it be able to handle left and right at the same time?
SNAAAKE
  • -Banned-
« Reply #2 on: September 09, 2003, 08:21:36 pm »
I dont have any ddr pad so no idea.
However,it does work perfectly with dualshock controller.
Has different inputs for analog sticks as well.
Axis is the analog stick and you have more inputs on directional pad.
Directional pad becomes axis when you turn off analog mode.
« Last Edit: September 09, 2003, 11:05:12 pm by SNAAAKE »
SirPoonga
  • Puck'em Up
« Reply #3 on: September 09, 2003, 08:24:47 pm »
Do you plan on making a control panel with this?  If so hook up two button to the left and right directional.  Bring up the game controllers control panel and see if you can push both at the same time.
I ask because many converters don't register up/down and left/right at the same time.  That doesn't work then with DDR.
« Last Edit: September 09, 2003, 08:25:45 pm by SirPoonga »
goldberg28115
  • Last login:April 17, 2004, 07:32:07 am
« Reply #4 on: September 09, 2003, 11:00:28 pm »
I have the same converter and unfortunatly it doesn't work right with ddr pads.  It reconizes the arrows as an axis and not buttons so you can't push two buttons at the same time.
Mooters
  • Last login:April 08, 2005, 02:48:35 pm
  • I Hate Mondays, I LOVE MOZZY (MOZILLA)
« Reply #5 on: September 09, 2003, 11:09:43 pm »
part # 26-304
I got a Radio Shack playstation to Usb converter like it but older the Cat # is  26-247
Its pretty old but it works and im tryin to find a way for MAME to recognise it so i can hack a psx pad for a cp.
Cant find pic try to get one and put it up for yall.
The Game Is NEVER Over!!!
hooded_paladin
  • Last login:November 06, 2013, 08:59:01 pm
  • Finch! hahaha
« Reply #6 on: September 10, 2003, 12:58:00 am »
darn radioshack.  EMS remains the king.
Modified by planetjay!  ;D
« Last Edit: September 11, 2003, 02:41:49 am by planetjay »
There is SO a spoon.
wboy
  • Last login:November 03, 2005, 05:09:19 pm
« Reply #7 on: September 10, 2003, 10:56:44 am »
Is there any PSX dance pads that allow configurable buttons?
The four buttons on the face of the could be used for up down left right, while the shoulders buttons could handle the diagonals.
Thus, none of the directional arrows are effectively used so this problem doesn't exist when using it with PC converters.
At worst, you could probably hack this beast of a unit!  ;D
http://www.play-asia.com/paOS-13-2-E-1-on-4-14.html
wboy
« Reply #8 on: September 10, 2003, 10:58:50 am »
Damn, how'd it manage to squeeze my most in the one above?  :o
