Author Topic: HELP : Need a MK2/UMK3 PCB Guru  (Read 1540 times)
Savannan
  • Last login:December 22, 2012, 10:53:06 pm
« on: August 25, 2011, 01:22:26 am »
Im dong a all in one MK cab.. currently I have a mk2 cab with all the stock wiring.  I picked up a UMK3 board from a fellow member on here.  When I disconnect my MK2 board and install UMK3 my graphics are ALL MESSED UP!!!  like a bad chip.  The fellow memeber said that the PCB worked before he shpped it USPS...the box wasnt damaged at all.  If I connect my MK2 board..everything looks normal
The only 2 things I can think of is.... 1) bad board 2) or perhaps of this....(red bar seperates UMK3/MK2 pcb)
I only have 1 wire which is +5v on the MK2 p4 connector...now when I move that to the p3 connector on the UMK3 board I know that I'm still missing +5v/2 grounds....is the p3/p4 wires used to give extra auxilliary power to the pcb?  by not having that addtional power/ground...would that mess the graphics up?
Any one came across this before?
Sav
PS.  The fellow memeber on here said he would warranty the board.  If worst comes to worse.....
« Last Edit: August 25, 2011, 01:24:57 am by Savannan »
Savannan
Re: HELP : Need a MK2/UMK3 PCB Guru
« Reply #1 on: August 25, 2011, 12:34:21 pm »
I got it goin...100% now.  I beilve it was the board...the shipper said it worked 100% but once I installed it the graphics were all messed up.  I took out the PCB and carefully pressed down on the chips....cruuuunch.....pluged it in and slowly but surely(after 3 or so mins) the graphics came to be normal...weird....
MonMotha
« Reply #2 on: August 25, 2011, 07:01:48 pm »
Re-seat all the socketed chips.  This process will normally dislodge any crud that's in the socket area and ensure a good connection.  If the leads are inordinately corroded, you may need to use a pencil eraser (gently so as not to bend the pin) to clean them.  One or more of the socketed chips could easily have become loose during shipping explaining the behavior (working before shipping but not after).
