Author Topic: Connect PC to Medium Res Arcade Monitor  (Read 2585 times)
Jollywest
  • Online Online
  • Last login:Today at 07:22:01 am
« on: August 21, 2011, 12:29:58 pm »
Hi, I'm just trying to find out a few things before I take the plunge and buy a cabinet to use for a Nebula SM2 Emu / MAME project.
It's a non-jamma cab with a medium resolution monitor. The plan is to use a Soft 15khz supported graphics card (Radeon HD 4650) with the Soft-15 software.
Is it a VGA breakout cable i need to connect the Graphics card to the Arcade monitor?
Thanks.
newmanfamilyvlogs
    • Newman Family Vlogs
Re: Connect PC to Medium Res Arcade Monitor
« Reply #1 on: August 21, 2011, 08:35:27 pm »
most people just wire up their own adapter, since lots of monitors have slightly different RGB connectors.
Jack Burton
« Reply #2 on: August 21, 2011, 10:44:01 pm »
The first order of business here is to find out the manufacturer and the model number of that monitor and report back here.  If you can't find that then it will be very helpful to take a picture of the video connector on the chassis (pcb) on the underside of the monitor.
Jollywest
  • Online Online
« Reply #3 on: August 22, 2011, 01:07:53 am »
Thanks. All I know so far is its a Sega Rally Upright cab with med res monitor, but once I get it I'll report back with make, model, pics etc...
StephenH
  • Last login:January 09, 2023, 06:15:45 am
« Reply #4 on: September 20, 2011, 09:54:42 pm »
For a medium res, you need a card that can output a 25Khz (EGA) signal unless the monitor is dual res.
ahofle
    • Arcade Ambience Project
« Reply #5 on: September 21, 2011, 10:04:29 am »
To be honest that's not a great monitor for emulation.  There are only a handful of medium resolution games (512x384 roughly).  The 99.9% of other games will have to be scaled which probably won't look great.  You would also need to use soft15khz and remove all the non 25khz resolutions.
