Author Topic: Best video card (Radeon HD 4890)  (Read 50550 times)
pyrojoe
  • Last login:November 16, 2013, 11:08:17 pm
Re: Best video card (Radeon HD 4890)
« Reply #40 on: April 26, 2012, 10:59:26 pm »
Hey guys,
Thinking of buying this for a new cab setup.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127613
Any thoughts/concerns?
Also, any real difference between getting a "9.1" card vs. a "6.5" card? Is it just the number of modes that I can create?
Thanks for the feedback!
-Joe
  • Last login:Yesterday at 05:28:27 pm
« Reply #41 on: April 27, 2012, 04:48:25 am »
Hi pyrojoe,
I'm assuming you've read this: http://forum.arcadecontrols.com/index.php?topic=113885.msg1223378#msg1223378
Well, the purpose of getting a "9.3" card is this driver version supports more modern cards with more powerful GPUs, that's all.
So that depends if you're intending to run stuff like SF IV or any 3D demanding emulator. Anyway, if that's the case, then my advice is to go at least for the HD 4650, because the HD 4350 has very basic specs on this regard (it can't hardly get 60 fps for SF IV with vsync on).
If you're only using MAME and 2D console emulators then you'd probably better stick to R 9250 or X300 and use the 6.5 drivers.
c0dehunter
  • Last login:July 07, 2014, 04:07:45 am
« Reply #42 on: May 28, 2012, 03:18:30 am »
Hello all,
I have a MSI R4350-MD1GD3H/LP, and I wanted to know if it is a real 4350 or not:
Here is a snapshot of its specifics, displayed by GPU-Z:
http://www.flickr.com/photos/48901682@N02/7271888086/#in/photostream/lightbox/
This is the 1GB DDR3 version, and I can attest that it works, since I am playing KOF 98 on my 1084S-D1 monitor and it looks gorgeous! Your 9.3 drivers installed on WinXP Pro x86 and I also installed Soft 15KHz on top of it (to get additional modelines, such as 384x240)
Nevertheless, to be on t he safe side, judging by the snapshot of my GPU, do you think it is a real 4350 or not?
« Last Edit: May 28, 2012, 03:25:46 am by c0dehunter »
iori01
  • Last login:May 18, 2024, 05:41:12 pm
« Reply #43 on: May 31, 2012, 07:27:10 am »
From what I know, RV710 is real 4350  ;)
c0dehunter
« Reply #44 on: June 08, 2012, 08:39:35 pm »
Sparki82
  • Last login:July 20, 2012, 07:01:03 pm
« Reply #45 on: July 16, 2012, 05:41:32 am »
Hi all,
Complete noob here, I've been reading this thread and believe that the ATI HD 4890 is still the highest GPU card that will work with groovymame. Is this correct? I found this card online and was wondering if this would work?
http://www.digitan.com.au/product.php?productid=63569&cat=1902&page=10
And where do I find the latest Emu_drivers for this card? Any suggestions or advice would be appreciated
krick
  • Gotta have blue hair.
« Reply #46 on: July 16, 2012, 10:52:50 am »
If you're using CRT_EmuDriver, the fastest ATI card supported is still the 4890 as far as I know.  I think that there are faster cards (possibly from Nvidia as well as ATI) that will work with GroovyMAME if you're using Soft15KHz instead of CRT_EmuDriver, but I'm not really that familiar with the latest and greatest in the Soft15KHz world.
Here's some relevant Soft15KHz threads you should probably read:
Soft-15KHz - slim new tool for 15KHz on normal vga cards
http://forum.arcadecontrols.com/index.php?topic=66402.0
What's the difference between Sailorsat's soft15kHz and CRT_Emudriver
http://forum.arcadecontrols.com/index.php?topic=119768.0
You can find a CRT_EmuDriver download mirror link in my signature, and there's download locations in the first post of one of the GroovyMAME sticky threads in this forum.
Note that recent testing indicates that you must use D3D mode in GroovyMAME to use the VMMaker "magic resolutions" feature with a 4xxx series ATI card and CRT_EmuDriver, though this doesn't appear to really be a drawback in practical use except in rare edge cases.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Sparki82
« Reply #47 on: July 17, 2012, 12:53:56 am »
Thanks Krick, appreciate the help.
Pixelhugger
  • Last login:October 14, 2025, 10:53:10 am
« Reply #48 on: October 19, 2012, 12:57:05 pm »
I'm building a new computer after my existing repurposed workstation turned out incompatible with AVGA.
I understand that the 4890 is the fastest card currently compatible with CRT Emu driver, but that most testing has been done with a 4350.
Is there any difference in compatibility between the 4890 and 4350. Does the patch raise any possible conflicts?
I'd like to get the faster card to support some of my son's favorite Lego games with higher recommended specs but after the incompatibility problems with AVGA, it has me nervous.
« Last Edit: October 19, 2012, 01:14:13 pm by Pixelhugger »
Project mega thread HERE
« Reply #49 on: October 21, 2012, 07:47:13 am »
While I haven't tested the HD 4890 myself, some folks here did and it worked fine for them. From the custom video mode support point of view, all HD 4xxx cards seem to be the same thing. For a cab, I wouldn't use the higher end ones unless you actually need to run non-MAME 3D games, because of the fan and their size.
Garion
  • Last login:January 29, 2017, 01:45:19 pm
Garion
« Reply #50 on: April 01, 2013, 06:37:21 pm »
What, specifically was different about the Radeon HD 4890 that required a driver modification?
Probably the HD 4890 model was not available yet when Catalyst 9.3 was released. However, I just needed to add its hardware PCI ID to the driver's installation files to get it supported.
So the driver's binaries are exactly the same (it won't affect previous models at all).
Is it possible do this with HD4770? Not able to install with 9.3 XP32 due to id.
Edit: Looking inet its PCI ID 1002:94b3
Thanks,
Francisco
P.S.: gracias por tu trabajo y soporte a groovymame.
« Last Edit: April 01, 2013, 09:28:53 pm by Garion »
« Reply #51 on: April 02, 2013, 05:54:06 pm »
Yes, it is possible. It's not difficult actually, just editing some files.
Garion
« Reply #52 on: April 02, 2013, 06:10:51 pm »
Thanks Calamity.
I tried do that myself editing an inf and an ini, first download official driver, copy the 4770 lines and paste in your driver but..... it didnt work  :dunno
Second I try, as a had a X700SE working with GM and your 9.3, was install the 4770 as a 4890 vía control panel. It works perfect. Then I create modelines with vmmaker and reboot. No way.... I get some kind of 15khz because CRT screen detect signal but no picture at all.
« Reply #53 on: April 02, 2013, 06:18:31 pm »
Have you tried the DVI output with a DVI-VGA adapter?
Garion
Garion
« Reply #54 on: April 02, 2013, 07:09:03 pm »
Yes, two VGA adapters tested. 4770 only dvi both outputs. If I try adapter via vga to lcd then unsupported frequencies, same via CRT detected signal but black screen. Tomorrow I'll try again. Maybe its due not proper uninstall of 9.3 x700 driver or wrong install due not right 4770 inf (but all later hd47x and 48x use R7x install...)
Tests done without any lcd attached to avoid screen detection on start.
« Reply #55 on: April 03, 2013, 04:34:51 pm »
Hi Garion,
Post your modified files here (use the attachments), so I can have a look.
Garion
« Reply #56 on: April 03, 2013, 07:12:49 pm »
I mod CX_76825.INI and CX_76825.INF but I forgot INSTALL.INI  :banghead:
changes I did:
INSTALL.INI
Calamity install.ini -> None
Reference Ati 9.5 (first I found HD4770)-> twice 94B3
R6_6=DriverPath_R6_6,0x94B3:0x29001682,0x94C1:0x21741458,0x9405,0x95C5:0x3033148C,0x9613,0x954F,0x95C0:0x3000148C,0x94C3:0x04021028,0x9490,0x94C3:0x11051462,0x9616,0x94C1:0x0D021002,0x94C3:0xE400174B,0x9501:0x25421002,0x95C5:0x01041A93
DriverPath_R6_6=\XP_INF,CX_80257.INF
R6_9=DriverPath_R6_9,0x94C3:0x01011A93,0x9440:0x24451682,0x9440:0x24441682,0x9440:0x24411682,0x9440:0x24401682,0x94C7,0x9598:0x3000148C,0x94C3:0x22471787,0x9598:0x4580174B,0x94C1,0x94B3,0x94C3:0x11041462,0x9588,0x94C3:0x203817AF
DriverPath_R6_9=\XP_INF,CX_80257.INF
CX_???.INI
Calamity CX_76825.ini -> I add only in bold:
R6_6=DriverPath_R6_6,0x94B3:0x29001682,0x5B60:0x1B601002,0x4170:0x000C18D4,0x9505:0x3000148C,0x556A,0x9598:0x3001148C,0x5B73:0x30011787,0x7187:0x30001569,0x4150:0x47721002,0x566F:0x148D148C,0x791F,0x94C3:0x03421002,0x4B49:0x00021002,0x7140:0x30001787
DriverPath_R6_6=\XP_INF,CX_76825.INF
and
R6_9=DriverPath_R6_9,0x7162:0x2162148C,0x3E70:0x0000147B,0x71A7:0x30011545,0x95C5:0x301017AF,0x5D6F:0x2161148C,0x4175,0x5E6D,0x554B:0x125018BC,0x7146:0x03221002,0x94B3,0x5B60:0x060018BC,0x5549:0x153218BC,0x7166:0x300117AF,0x554F:0x21361458
DriverPath_R6_9=\XP_INF,CX_76825.INF
Taken from reference 9.5 driver CX_80257.INI
CX_???.INF
Calamity CX_76825.INF -> I add between HD4670 and 4800 two sentences:
"ATI Radeon HD 4770" = ati2mtag_R7X, PCI\VEN_1002&DEV_94B3&SUBSYS_1170174B
but in Reference 9.5 CX_80257.INF the SUBSYS is different from my SUBSYS I saw in hardware info (control panel xp). I think I test both subsys but lot of things done and I can remember 100%.  In official ATI Driver 2 sentences but:
"ATI Radeon HD 4770" = ati2mtag_R7X, PCI\VEN_1002&DEV_94B3&SUBSYS_29001682
"ATI Radeon HD 4770 " = ati2mtag_R7X, PCI\VEN_1002&DEV_94B3
As you see really I try do this myself but if you can help it would be appreciated.
I attach my mod files.
regards
Garion
« Last Edit: April 03, 2013, 07:17:58 pm by Garion »
Garion
« Reply #57 on: April 05, 2013, 05:30:18 pm »
finally I mod the install  ;D
works perfect with HD4770
« Reply #58 on: April 05, 2013, 05:35:06 pm »
Great! So what did you do?
Garion
« Reply #59 on: April 05, 2013, 07:04:13 pm »
what I wrote a couple days ago + mod the install.ini I forgot + and as I didn´t know what SUBSYS was right I include both (my HD4470 subsys and standard HD4770 in 9.5 driver)
I´m posting now from 640x480 Trinitron Pal (testing some mame.ini ranges from old "scart thread" and trinitron crt´s). Lets see.
« Reply #60 on: April 06, 2013, 11:36:46 am »
Ah ok. Sorry for the late response. It's good that you already figured it out. It's better not specifying the subsystem at all, so all subsystems are accepted.
CzechMate
  • Last login:August 23, 2020, 12:08:27 pm
« Reply #61 on: August 23, 2020, 11:48:07 am »
Hello people!I'm new in the forum and I'm trying to download the calamity's MODIFIED DRIVERS for my ATI HD4890 but the files which were uploaded by you (drivers for WINx86 & WINx64) are not available anymore. Please, could anyone upload them again? Thanks in advance
