Author Topic: IPAC2 and WinIPAC Time out error  (Read 4698 times)
djm858
  • Last login:March 27, 2015, 09:05:10 pm
« on: August 18, 2011, 09:39:33 pm »
Hey guys,
I'm having a recent issue with getting a time-out error when trying to program my IPAC2.  I've searched and seen many people had a similar issue, but none of their solutions worked for me.  The weird thing is, I was able to re-program the IPAC2 twice before, but now it refuses.
Reprogram 1: No issues.  Reprogrammed quickly and worked great.
Reprogram 2: (A few days later) Started getting a time-out error, but even with that it'd still reprogram the keys (It would say time-out but the keys were changed anyway).
Reprogram 3: (A couple days after 2) Time-out error and nothing reprograms.
I'm running Win7 Ultimate and I have the IPAC2 hooked up via PS/2.  All the buttons register when I push them so there doesn't seem to be a short/lose connection anywhere.  I always run as Admin.  I tried reinstalling WinIPAC to no avail.  I just recently (within 1 month) purchased this IPAC2 board so I don't think it's an issue with old hardware.
Any insights?
Thanks,
DashRendar
Re: IPAC2 and WinIPAC Time out error
« Reply #1 on: August 19, 2011, 10:26:30 am »
Since you have it hooked up with PS/2, make sure WinIPAC is set for PS/2 rather than USB.
I think that might cause the symptom you're seeing.
djm858
« Reply #2 on: August 19, 2011, 10:56:29 am »
Thanks for the reply, Dash.
I can confirm that the options are set to the 32input IPAC2 and the PS/2 input.  I tested to see what it would do if I changed it to USB option setting and it gave a different error message, Failed to Program instead of Time Out.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: August 20, 2011, 05:45:55 am »
Can you ensure you are using the latest WinIPAC version by downloading it from www.ultimarc.com/download.html. Uninstall the existing version and reinstall with the board connected.
When you mention USB, do you have the USB and the PS/2 cables? If you also have the USB try it in USB mode, again re-install with the board connected (via USB).
Can assist further by email if needed.
teacworms
  • Newbie
  • Last login:December 10, 2012, 02:01:06 am
« Reply #4 on: December 09, 2012, 06:10:27 pm »
Hey there,
I know this is almost a year later, but I'm wondering if you resolved your issue.  I'm having the same exact problem you described above.
-Worms
