Author Topic: Need help hooking up a Tempest spinner  (Read 1374 times)
t3design
  • Last login:Yesterday at 08:51:28 pm
  • Orange Power! Go Pokes!
    • Cowboy Arcade Project
« on: August 16, 2011, 11:56:27 am »
I am toying with the idea of using an original Tempest spinner on my cab. I have the ability in my shop to redo the bushings and get the thing to spin smoothly and quietly. I have two questions?
First: Is the Opti-Pac from Ultimarc the best way to hook this up? I haven't bought one yet, but the web site makes it sound simple. How will I know which wires from the spinner go where?
Second: Is the resulting input and game control going to be good? I have a Turbo Twist 2 that I was planning on using until I got a hold of the original Tempest optical spinner. Something about having that in my cab appeals to me, but I don't want to degrade my game playing.
Any help or advice is appreciated....
t3
Cowboy Arcade Project ThreadCowboy Arcade Project Website
If you are an obsessive/compulsive pyromaniac, you better make sure you wear flame retardant pajamas.
RandyT
    • GroovyGameGear.com
Re: Need help hooking up a Tempest spinner
« Reply #1 on: August 18, 2011, 02:08:16 pm »
If you have a TurboTwist 2 already, you can connect the Tempest spinner to the interface board (using the Y axis) to compare the performance.  For permanent installation of the Tempest spinner, you can get an Opti-Wiz, which is essentially the same board.
For Tempest, the original control will be great.  But, if you plan to play games which used a dial (potentiometer) based control, or games which require high resolution, like Arkanoid, you will no longer have the optimal resolution for accurate gameplay.
RandyT
