Author Topic: Quick Painting Question  (Read 1117 times)
General Zod
  • Last login:June 23, 2005, 03:58:28 pm
  • Banned
« on: September 08, 2003, 08:55:01 pm »
Today I decided to touch up the back of my cabinet with a little primer and spray paint. I'm not to pleased with the results. Is it possible to use a roller and a latex finish on the cab?
It's particle board, and I need to sand it down again, and pretty much start from scratch. Any recommdendations on what I should do?
Thank you ,
Michael
Apollo
    • Eight Bells
Re:Quick Painting Question
« Reply #1 on: September 08, 2003, 09:05:03 pm »
Once the factory finish on particle board is gone you need to use a special primer. Basically you want to go to the paint shop and ask for a primer for hard to paint surfaces i.e. lose surfaces or formica. It's a bit more expensive than normal primer but well worth it if you want to do a good job. I used Dulux Primerlock.
Then you can pretty much paint with whatever paint you want to.
General Zod
  • Banned
« Reply #2 on: September 08, 2003, 09:24:55 pm »
That sounds good Apollo. How is it applied to the surface I'm going to paint?
Will I still need to sand it down before I prime the surface?
Also, what is the best type of roller for using on particle board?
Thank you for your help ! :-)
Michael
pointdablame
« Reply #3 on: September 08, 2003, 10:19:58 pm »
I would think you'd want to use a foam roller for particle board just like you'd want to use with MDF. I haven't gone and painted my cab yet, but I've read lots of posts saying this is the way to go.
first off your and idiot
