Author Topic: Help wiring up UK IEC switched socket  (Read 6286 times)
jimmy2x2x
« on: August 09, 2011, 03:48:54 pm »
I just bought this IEC switched socket for my cab and could use some help wiring it up.
  • Last login:January 26, 2026, 07:56:08 pm
Re: Help wiring up UK IEC switched socket
« Reply #1 on: August 09, 2011, 07:58:24 pm »
how i would do it...
please note i live in canada where the standard electrical conductors is white/black/green
i believe:
brown=black (our hot or live)
blue=white (our neutral)
green=green (ground)
i have labeled the hot(live)/neutral/ground connections in case i'm incorrect.
jimmy2x2x
« Reply #2 on: August 10, 2011, 05:16:38 pm »
Worked great! Thanks  :cheers:
jameth
  • Last login:January 28, 2015, 04:04:08 pm
« Reply #3 on: August 16, 2011, 05:55:40 am »
Brilliant, thanks for this - I've been searching the web like crazy for some info on wiring up a switched IEC socket, nothing seems to exist! Assuming that this is a DPST switch, am I right in thinking that for increased safety you can also feed the neutral wire through the other two switch tabs?
mgb
  • North East, US
« Reply #4 on: August 16, 2011, 07:08:19 am »
Yeah,
as long as its a 2 pole, you can also switch the neutral.
jameth
« Reply #5 on: August 16, 2011, 08:46:08 am »
That's great, thanks a lot!
