Author Topic: Track and Field Hi Scores / World Records  (Read 2596 times)
blubberpud
  • Last login:May 15, 2021, 10:04:04 am
« on: August 08, 2011, 12:34:58 pm »
Please let me know if there is a more appropriate area for this post...
I'm running MAME 0.137 and would like to know if it is possible to clear the scores in "Track and Field"
I've found some posts regarding "HiToText" and am able see and update the scores in the trackfld.nv (nvram) file, but only to better scores. (also the -e switch to erase doesn't work - array error)
Basically I want to set all the records easy so my friends and I can have our own instead of trying to beat the crazy default ones that come with the game?
Thx, J
DillonFoulds
Re: Track and Field Hi Scores / World Records
« Reply #1 on: August 09, 2011, 12:34:19 am »
DO NOT LAUNCH IT FROM A FRONT-END TO DO THIS, RUN THE GAME DIRECTLY FROM MAME!
Delete your nvram file, run the game. Push Tab, and go to the DIP settings. Flip the one to forget high scores (don't recall the exact terminology off hand). Go back to MAME, close the game and reopen it. Go back into the DIP settings and set the game to save high scores. This is let the rom fully re-initialize your nvram file. Alternatively, there MAY be something in the F2 settings, but i'm fairly certain that it was just in the DIP settings.
Doing this will put everything back to AAA, BBB, CCC, or whatever, and will allow you to properly save the records for the 100m dash and hurdles. As for getting the world records to lower than stock... good luck! Practice makes perfect, just develop your technique!
« Last Edit: August 09, 2011, 12:36:17 am by DillonFoulds »
