Author Topic: Has anyone used a remote surge protector to control power?  (Read 1928 times)
upper2bits
  • Last login:December 20, 2011, 05:52:45 pm
« on: August 08, 2011, 08:12:01 am »
My cab will have a laptop, LCD, light and speakers. I would prefer one switch on the outside to turn them all on so I was looking at something like this.
http://www.amazon.com/Belkin-Conserve-Switch-F7C01008q-Energy-Saving/dp/B003P2UMNK/ref=pd_luc_sim_04_02_t_lh
bkenobi
Re: Has anyone used a remote surge protector to control power?
« Reply #1 on: August 08, 2011, 11:36:08 am »
If you are using a laptop, you are going to have a lot more options than most people.  Since your PC has battery backup built right in, you can simply tell it to turn off when external power is lost.  When you want to shut it off, unplug the power (or flip the switch) and you're golden!
« Reply #2 on: August 08, 2011, 11:41:26 am »
You could use a switch like that to turn everything on, but you have to be careful about the turn off. Turning off a computer by cutting the power can be rough on your laptop. You would need to shut it down first.
upper2bits
« Reply #3 on: August 08, 2011, 12:22:33 pm »
yeah, the laptop works great for auto off..I have it go into hibernate if it's on battery for more than 5 minutes so I'll just kill the power and it will go off on it's own.  The only issue I have solve is how to turn it back on which I'm able to figure out.
« Reply #4 on: August 08, 2011, 12:28:45 pm »
A lot of computers have a power up when plugged in setting. I would start by checking your bios options.  :cheers:
upper2bits
« Reply #5 on: August 08, 2011, 12:33:13 pm »
Desktops do but laptops don't since they usually are running on battery.  The only option in my BOIS for power on is LAN and I was unable to find how to take this.
cigardude
  • Last login:December 20, 2017, 01:29:48 pm
« Reply #6 on: August 08, 2011, 01:34:17 pm »
You will need to somehow extend the power switch on your notebook to the outside of the cabinet.
http://forum.arcadecontrols.com/index.php?topic=84566.0;all
http://forum.arcadecontrols.com/index.php?topic=84113.0;all
