Author Topic: Pic of inside my cab - Power supply question  (Read 1656 times)
Savannan
  • Last login:December 22, 2012, 10:53:06 pm
« on: August 06, 2011, 12:56:54 pm »
Ok I take it that the power supply is located under the PCB..silver box with terminals coming out...and the transformer is mounted on the base with all the grounds coming out....My plans are putting mk-mk4 in this cab.  goin to use use one of the two jamma switchers out there...havent made up my mind yet...
Now since im putting 2 600w PC power supplies in this cabinet... I dont need that beast of a transformer (right?)...or do I need it for the monitor?
thanks
Sav
Savannan
Re: Pic of inside my cab - Power supply question
« Reply #1 on: August 06, 2011, 12:57:19 pm »
opps ... heres the pic
« Reply #2 on: August 06, 2011, 01:06:44 pm »
Yes, you need the isolation transformer for your monitor.
