Author Topic: Wizard of Wor cabinet measurements  (Read 2696 times)
jibmums
  • Last login:June 24, 2018, 01:08:16 am
« on: August 06, 2011, 11:34:10 am »
Would someone with a WoW mind taking a few measurements for me?  This would have to be from a cabinet that matches my picture, as opposed to one that has a single front panel.  Thanks guys.  In the picture -
A = Upper white panel as measured from bottom of CP
B = Lower black panel, including door or whatever that is at the bottom
C = Space from bottom of lower black panel to bottom of side panel (not to floor, I don't want to include the height of the legs/feet
D = Upper white panel to front edge of side panel (not including T-molding)
E = Lower black panel to front edge of side panel (not including t-molding)
F = Bottom of coin door frame to bottom of upper white panel
Hoopz
  • Last login:December 02, 2025, 03:05:33 pm
  • Intellivision Rocks!
Re: Wizard of Wor cabinet measurements
« Reply #1 on: August 06, 2011, 01:56:06 pm »
That's my favorite game.   :cheers:
Good luck getting your measurements.
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
« Reply #2 on: August 06, 2011, 03:14:19 pm »
can do
jibmums
« Reply #3 on: August 13, 2011, 08:58:22 am »
bump
cw
    • The Cab
« Reply #4 on: August 13, 2011, 10:08:07 pm »
a 19 3/8
b 12 3/16
c 1 1/8
d 5/16   to outside edge of tmolding
e 1/2     to outside edge of tmolding
f 6 3/4
jibmums
« Reply #5 on: August 16, 2011, 10:19:07 am »
Thank you CW!  Check your pm's.
