Author Topic: Properly calibrating monitor for dreamcast?  (Read 1288 times)
gabe
  • Last login:September 10, 2012, 12:44:38 pm
« on: August 04, 2011, 11:48:21 am »
I just purchased a 21" CRT monitor which I intend to use exclusively as a Sega Dreamcast display, connected via VGA box.
Does anyone have any tips on how I might go about properly calibrating the monitor for this purpose?
Is my best bet to hook it up to a PC and use one of the many tools? Would calibrating it on a PC be completely useless, as the PC is NOT the Dreamcast? Should I just go with the factory defaults and tweak it until I say "that looks pretty good"?
MonMotha
Re: Properly calibrating monitor for dreamcast?
« Reply #1 on: August 04, 2011, 05:37:13 pm »
The dreamcast VGA box and PC should output comparable signals at 640x480 in terms of video levels, so you can probably just set brightness/contrast with the PC and get it pretty darned close.  You may have to tweak the geometry some when you move from the PC to the DC.
gabe
« Reply #2 on: August 05, 2011, 10:33:33 am »
It turns out Artemio over at the Shmups forum has developed a tool for just such an occasion. If anyone is interested:
240p test suite for Dreamcast, Genesis and Sega CD
