Author Topic: Running DOS On A Windows Machine  (Read 3728 times)
JeepMonkey
  • Last login:July 13, 2012, 01:51:24 pm
« on: August 04, 2011, 07:02:01 am »
I have an old industrial controller that is programmed in DOS.
It seems like we need a machine that will boot to DOS mode, but out PII 233 NT machine and two year old XP machine will not boot to DOS mode.  If I recall, these machines to not run actual full DOS, more of a partial or emulated DOS?
Is there a software program, preferably downloadable, that will either allow one of these machines to boot to DOS or run actual full blown DOS?
Pins:  Theatre Of Magic, JP The Lost World, Revenge From Mars
CCM
Re: Running DOS On A Windows Machine
« Reply #1 on: August 04, 2011, 07:48:23 am »
Maybe DOSBox?   :dunno
http://www.dosbox.com/
Cenobyte
  • Last login:August 06, 2013, 06:26:57 am
« Reply #2 on: August 04, 2011, 08:07:49 am »
A DOS box will not work, since that is only an emulation of the true DOS environment. A lot of things don't work, especially dirty programmed, low level stuff that Windows will prevent from running.
If you want to run true DOS on a Windows XP machine, you can. You can install a boot selector with a second partition that contains MS-DOS (or Free-DOS) and SRM. When you switch on your computer, you can select Windows or DOS to boot. Read here on how to install a boot selector with Free-DOS on your Windows machine.
JeepMonkey
« Reply #3 on: August 04, 2011, 08:26:42 am »
Would any software running DOS on XP give me any more "functionality" than the DOS that comes loaded on XP?  Maybe Microsoft Virtual PC?
Cenobyte
« Reply #4 on: August 04, 2011, 08:56:48 am »
The DOS box in Windows XP is just an emulation of true MS-DOS. I once wrote a piece of software that times slot cars and because these cars are so darn small and fast, they passed the sensors before my software could detect them. I added a routine that sped up the internal PC clock, which included a bit of low level tinkering. As a result, my software does not run in a Dos box in Windows, because Windows will prevent tinkering with the internal clock. There are a lot of low level tricks in MS-DOS that can give you an advantage, but they will not work in Windows XP's Dos box. Older versions of DOS Mame also profited from such tricks.
« Reply #5 on: August 04, 2011, 09:45:14 am »
You could give FreeDOS a shot.  I have used it and have not seen it fail to run a DOS program.  It also adds a lot of things like TCP/IP, FTP, telnet, DHCP.  There are a bunch of other packages you can add, too, linux style.
knave
  • Last login:October 15, 2025, 04:12:19 pm
« Reply #6 on: August 04, 2011, 12:04:57 pm »
You don't even need a partition, DOS can run from a floppy (if you still have a drive) I've used bootable USB drives in the past as well.
Cenobyte
« Reply #7 on: August 04, 2011, 12:14:15 pm »
Also be prepared that you might NOT be able to read your Windows hard drive, if it's formatted as a NTFS partition, since MS-DOS can't read that.
« Reply #8 on: August 04, 2011, 12:23:34 pm »
I love that FreeDOS is updateable via the net and cmdline RPM style.  That is just awesome.  DOS with an embedded virus scanner, torrent client, and webserver..   :notworthy:
Ed_McCarron
« Reply #9 on: August 04, 2011, 02:06:25 pm »
Also, bear in mind, if the PLC communicates via a comm port -- DosBOX might or might not play nice.  Best bet is to boot to a dos disk -- but newer hardware may not fly under dos.
I used to keep an old Toshiba T1000 around for DOS work on oddball controllers.  Don't see much need for them anymore -- customers have phased most of the older stuff out.
lilshawn
  • Last login:March 16, 2026, 03:44:11 pm
« Reply #10 on: August 04, 2011, 02:29:29 pm »
what about http://www.bootdisk.com
Download the file to your C: drive, put a fresh disk in your A: drive, then click on the file to create the bootdisk. (if you still have a floppy drive)  :dunno
JeepMonkey
« Reply #11 on: August 05, 2011, 07:03:05 am »
-- if the PLC communicates via a comm port --
Are you a PLC programmer?  That is my main job function.  Mostly Allen Bradley.
ark_ader
  • I glow in the dark.
« Reply #12 on: August 05, 2011, 05:03:55 pm »
eBay is your friend in these situations.
Cenobyte
Ed_McCarron
« Reply #14 on: August 07, 2011, 07:44:03 pm »
System Integrator.  In the panels I build, my mainstay has been the Bristol Babcock 33XX series, now Controlwave.
In existing installs, I work with the AB SLC series, Modicon M340, with a sprinkling of ScadaPAK thrown in for good measure.  I dabble with a handful of HMI packages, too.
Whatever the customer needs.  Hell, I wash windows and mow lawns if they want to pay me to. :)
