Author Topic: cheap 4 player solution?  (Read 1439 times)
dpp
  • Last login:September 10, 2003, 08:15:24 pm
  • I'm a llama! wooooo
« on: September 08, 2003, 03:47:51 am »
I tried searching for the answer to this so excuse me if this has been asked a million times before.. But is it possible to hook up 2 HotRodSEs for a cheap and easy 4 player solution? I don't have time to build my own, and I don't want to throw down $700 for a slikstik quad.. this is more for the purpose of novelty entertainment and not necissaily a hobby or a project... i'm planning on doing that in a couple years perhaps :).. but for right now all i want is a controller to hook up to my computer, and would love 4 player possibilities.
thanks
paigeoliver
  • Awesome face!
Re:cheap 4 player solution?
« Reply #1 on: September 08, 2003, 07:46:20 am »
The answer to that is no, since the hotrods are not programmable. Both would send the same keys to the computer.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: September 08, 2003, 08:35:49 am »
The more involved answer is possibly with some work.
Could probably be done with 2 X-Arcades, which are programmable and USB capable.
Could possibly be done with 2 X-Arcades or 2 HotRods using a PS/2 splitter, but I have my doubts and don't recommend this.  Here's a HotRod option.
Leave HotRod 1 as is.  Remove the proprietary interface from HotRod 2 and wire all controls to a $43 I-PAC/2 USB interface which you reprogram to be different from HotRod 1.
Problem solved.
Either of these will run you $250 - $350, much less than a SlikStik quad.  Another advantage is you are only giving up the desktop real estate when you really need it.
dpp
« Reply #3 on: September 08, 2003, 06:05:24 pm »
thanks guys -- i'll probably just end up getting 2 x-arcades, then.. i didn't know that the hotrods weren't programmable. thanks for the info.
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: September 09, 2003, 07:59:05 am »
Well, now that I cleared some things up, let me confuse you more :P
Two X-Arcades - $300 (maybe less off E-bay) $360 if you get them both with the Apple kit (which you need since they can't both be PS/2).  $330 if you get one PS/2 and one USB. Somewhat awkward encoder, but ability to use with console games.
Two Hotrods and a USB I-PAC - $241 (HotRod is on sale for $99) now.  Only one HotRod will be programmable, but this is the least expensive working solution.
Two Hotrods and two USB I-PAC's - $284 Gives you programmability and USB hot-swappability on both HotRods and a better interface.
X-Arcade USB and Hotrod PS/2 - $279 Gives you the ability to play console games and MAME, if you can deal with the non-programmable interface and the different looking panels.
X-Arcade PC and HotRod USB  - $291  Ability to play console games and program your HotRod, if you can deal with the different looking panels.
X-Arcade USB and HotRod USB - $321  Same as above, but both units are hot swappable.
Ok, my brain hurts, I'll stop now!!!
« Last Edit: September 09, 2003, 08:06:48 am by Tiger-Heli »
dpp
« Reply #5 on: September 10, 2003, 08:26:37 pm »
thanks again for the additional info! i really appreciate it  ;)
