Author Topic: Samurai Shodown Edge of Destiny out for tinkering  (Read 21137 times)
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« on: August 03, 2011, 09:25:30 pm »
The usual outlet has finally released the game (arcade, Taito Type X2) but they have not been able to get it to work with the current loader. They decided to release it in the hopes that somebody does.
Stay tuned.
"The Manuel"
GreatLamer
  • Last login:July 17, 2025, 04:27:37 pm
Re: Samurai Shodown Edge of Destiny out for tinkering
« Reply #1 on: August 06, 2011, 04:31:04 am »
Cool.
Triangel7D
  • Last login:September 10, 2017, 01:06:09 pm
« Reply #2 on: August 06, 2011, 08:41:32 am »
I think the "usual outlet" may now have a hack up that makes it work. Man, this game is huge (4GB)!
mshelbz
  • Last login:August 13, 2011, 02:40:13 am
« Reply #3 on: August 09, 2011, 07:27:12 pm »
Anyone know a way to change the controls to match my MAME cab setup?
TheManuel
« Reply #4 on: August 09, 2011, 09:04:17 pm »
Right here if you are up for changing the game.exe with a hex editor.
You could also use autohotkey.
"The Manuel"
mshelbz
« Reply #5 on: August 09, 2011, 09:33:54 pm »
I can't view the thread, it that in the VIP forum?  My donation expired.
TheManuel
« Reply #6 on: August 09, 2011, 09:37:16 pm »
Sorry, you are right.  I forgot that forum is not open.
Follow the instructions below; any hex editor will do.
I had gotten around the issue using ahk but I liked this solution better, so I did that instead.
Let me know if you have issues.
; This text shows where to edit controls in the game.exe for Samurai Shodown - Edge of Destiny
; Open game.exe in UltraEdit, hit Ctrl+G and paste the 0x######### number below to find the key you want to change
; Change it's value to the hex of the key you want instead.
; Original Controls:
; Player 1:               Player 2:
; Up - Up      @ 0x000A8238 hex C8   Num 8 - Up      @ 0x000A8323 hex 48
; Down - Down      @ 0x000A8248 hex D0   Num 2 - Down      @ 0x000A8339 hex 50
; Left - Left      @ 0x000A8254 hex CB   Num 4 - Left      @ 0x000A834B hex 4B
; Right - Right      @ 0x000A825C hex CD   Num 6 - Right      @ 0x000A8356 hex 4D
; A - Kick      @ 0x000A8290 hex 1E   G - Kick      @ 0x000A8397 hex 22
; S - Special      @ 0x000A82A0 hex 1F   H - Special      @ 0x000A83AD hex 23
; Z - Horizontal Slash   @ 0x000A826C hex 2C   B - Horizontal Slash   @ 0x000A8361 hex 30
; X - Vertical Slash   @ 0x000A8278 hex 2D   N - Vertical Slash   @ 0x000A8373 hex 31
; F1 - Start      @ 0x000A82FB hex 3B   F5 - Start      @ 0x000A8426 hex 3F
; F2 - Coin      @ 0x000A8311 hex 3C   F6 - Coin      @ 0x000A821D hex 40
; | Scan code table: HEX = KEY          |
;          10 = Q      20 = D      30 = B         40 = F6         50 = Numpad 2      ?? = End
; 01 = ESC      11 = W      21 = F      31 = N         41 = F7         51 = Numpad 3      ?? = F11
; 02 = 1      12 = E      22 = G      32 = M         42 = F8         52 = Numpad 0      ?? = F12
; 03 = 2      13 = R      23 = H      33 = ,         43 = F9         53 = Numpad .
; 04 = 3      14 = T      24 = J      34 = .         44 = F10      ?? = Numpad /
; 05 = 4      15 = Y      25 = K      35 = /         45 = Num Lock      ?? = Numpad Enter
; 06 = 5      16 = U      26 = L      36 = Right Shift   46 = Scroll Lock   ?? = Right Alt
; 07 = 6      17 = I      27 = ;      37 = Numpad *      47 = Numpad 7      ?? = Right Ctrl
; 08 = 7      18 = O      28 = '      38 = Left Alt      48 = Numpad 8      C8 = Up Arrow
; 09 = 8      19 = P      29 = `      39 = Spacebar      49 = Numpad 9      C9 = Page Up
; 0A = 9      1A = [      2A = Left Shift   3A = Caps Lock      4A = Numpad -      CD = Right Arrow
; 0B = 0      1B = ]      2B = \      3B = F1         4B = Numpad 4      D0 = Down Arrow
; 0C = -      1C = Enter   2C = Z      3C = F2         4C = Numpad 5      D1 = Page Down
; 0D = =      1D = Left Ctrl   2D = X      3D = F3         4D = Numpad 6      D2 = Insert
; 0E = Backspace   1E = A      2E = C      3E = F4         4E = Numpad +      D3 = Delete
; 0F = Tab      1F = S      2F = V      3F = F5         4F = Numpad 1      ?? = Home
"The Manuel"
mshelbz
« Reply #7 on: August 09, 2011, 09:57:29 pm »
That's way over my head. Just going to hope a loader compatible game.exe comes out eventually
« Last Edit: August 09, 2011, 09:59:59 pm by mshelbz »
mshelbz
« Reply #8 on: August 09, 2011, 10:11:32 pm »
Giving it a stab...what about test switch?
Thanks!  Got it all working except the test switch to change to English and enable blood
« Last Edit: August 09, 2011, 10:27:15 pm by mshelbz »
TheManuel
« Reply #9 on: August 09, 2011, 10:47:14 pm »
I'm afraid the test mode button is either not in the exe or has not been identified.
Some people have managed to load the game using typex_loader (like the other TTX games), in Win 7 64bit, using XP SP3 compatibility mode, so they can configure the keys using typex_config.  This did not work for me nor many others, though.
We'll have to wait on that one.
"The Manuel"
mshelbz
« Reply #10 on: August 09, 2011, 11:08:52 pm »
Found out a workaround.  Make sure your corrected file is named game.exe and run this program http://www.megaupload.com/?d=U1RC1DML
After that it will create a folder named SV in the same folder you are in.  Copy the files in this link into it and it will enable blood and Engrish
https://rapidshare.com/files/1461401925/sv.rar
While it's no test mode, it at least gives us the most sought after changes.
Now if I can figure out how to get KOF:MIA working
TheManuel
« Reply #11 on: August 11, 2011, 03:27:21 pm »
What happens when you try to run KOFMIRA?
"The Manuel"
Dazz
  • HyperSpin Team
    • VPUniverse
« Reply #12 on: August 11, 2011, 05:08:51 pm »
Pssst... donations don't expire on the HS site.  Accounts will only get banned for violating the TOS.
mshelbz
« Reply #13 on: August 11, 2011, 10:31:20 pm »
I realized that after I posted lol Chrome didn't auto log me in  :banghead:
kokoski
  • Last login:December 28, 2018, 01:13:29 am
« Reply #14 on: August 24, 2011, 11:46:56 am »
When I try to load it up my comp says it's missing a dic32.dll file, a file which my bitdefender called a worm, anyone have  any ideas?
« Reply #15 on: August 29, 2011, 07:35:06 pm »
I was messing around with remapping the controls with a hex editor and noticed two extra controls.
By default, C makes P1 jump backwards & M makes P2 jump forwards.  ???
Can't find any buttons mapped that makes them jump in the other directions.
I remapped them because they interfered with the buttons I wanted to use for other controls.
(they are at 8284 & 8380 EDIT:8385 respectively)
Were there more than 4 buttons on the original control panel?
« Last Edit: August 29, 2011, 08:51:06 pm by BadMouth »
« Reply #16 on: August 29, 2011, 08:20:51 pm »
Tried this and now the game crashes.  :-\
Anyone else have a problem with it?
EDIT: Nevermind.  Started from scratch and followed these steps before remapping the keys and it works fine.
         I probably messed something up the last time I had it open in the hex editor.
         Just gotta remap my keys again, then it should be ready for primetime  ;D
« Last Edit: August 29, 2011, 08:33:58 pm by BadMouth »
djvj
  • Last login:August 12, 2022, 02:39:36 pm
« Reply #17 on: August 30, 2011, 12:06:44 am »
nm, wrong game
« Last Edit: August 30, 2011, 12:08:41 am by djvj »
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
HowTo mod GunCon2 with Aimtraks
nexnox
  • Newbie
  • Last login:February 27, 2013, 01:30:36 am
« Reply #18 on: February 27, 2013, 01:30:36 am »
So, I have tried to HEX edit my game..but everytime I run the launcher, the game.exe gets restored to a pre-edited state.
Shou
  • Newbie
  • Last login:June 26, 2013, 02:47:05 pm
« Reply #19 on: June 26, 2013, 02:33:35 pm »
Does anyone know if someone hacked the config file to have both Japanese language and blood?
fizen
  • Last login:November 08, 2018, 04:06:12 pm
« Reply #20 on: October 30, 2016, 07:01:46 am »
I'm wondering if anyone has managers to find the HEX address of the ESC (exit) key
I'd like to change the default.
gentlemagic
  • Last login:October 27, 2018, 08:22:18 am
« Reply #21 on: October 26, 2018, 09:20:05 am »
please help enable english and blood
TheManuel
« Reply #22 on: November 01, 2018, 09:32:01 am »
I had taken a long break from the hobby and I'm a little foggy on setting up Taito Type X games but I recently found this launcher.  I'm not sure if I found it here or in another forum but I intend to look into it and possibly migrate my hacky setup to this if it looks good.
"The Manuel"
