Author Topic: Problem with TV out :-/  (Read 1764 times)
LunarLoveLust
  • Last login:October 14, 2016, 02:43:26 pm
  • n00b :D
« on: September 07, 2003, 04:06:14 pm »
First off, i'm on XP using a Geforce4 Ti4200 128mb...
I'm using a flat panel monitor right now, and I notice a small line that goes horizontally through the screen and slowly travels up while playing games... This also happens when I use the TV-Out option
Any clue on how to fix this? Could it be bad connections or resolution settings?
Thanks for any help :)
TalkingOctopus
    • My Arcade
Re:Problem with TV out :-/
« Reply #1 on: September 07, 2003, 04:24:15 pm »
If it only happens during MAME then it is probably a MAME setting and not a hardware problem.  Try playing the game at a different resolution or refresh rate.
LunarLoveLust
  • n00b :D
« Reply #2 on: September 07, 2003, 04:27:00 pm »
Nope :( Happens with other emulators as well
Lemme test some more, I know for a fact SNES9x and MAME have this problem...
LunarLoveLust
  • n00b :D
« Reply #3 on: September 07, 2003, 04:32:25 pm »
Tested Gens... same problem...
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #4 on: September 07, 2003, 05:05:34 pm »
for the sake of argument... try using smootmame... and report back.
I'm guessing what you are seeing is often refered to as  "tearing"
(of course I may be, and frequently am wrong)
rampy
tom61
  • Last login:September 18, 2017, 12:46:56 am
« Reply #5 on: September 07, 2003, 06:18:26 pm »
I've encountered this before, and fixed it by getting better cables for video and audio. (oddly the cheap Radio Shack 1/8" to phono plug adapter was causing interference in the video)
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
« Reply #6 on: September 07, 2003, 08:30:19 pm »
I have this same problem.  I'm using an S-video to Composite adapter from svideocables.com (web address may be wrong :P)
Art
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
