Author Topic: Hyperspin won't start  (Read 13919 times)
ahofle
    • Arcade Ambience Project
« on: July 25, 2011, 10:51:16 am »
I'm trying to get Hyperspin running on my cab PC.  When I start it however, it just silently crashes (the process in task manager just vanishes with no error msg).  There is no error log in the hyperspin directory and I haven't been able to figure out the cause.  Has anyone else seen this issue?  Any suggestions?
abispac
  • Last login:January 31, 2026, 11:05:56 am
Re: Hyperspin won't start
« Reply #1 on: July 25, 2011, 01:26:11 pm »
I  had it once, turn out to be a virus, i scan my pc with avast, clean my pc erase the old hyperspin, installed again and it worked just fine, if thats the case you might wanna chek other software too...
ahofle
« Reply #2 on: July 25, 2011, 04:38:10 pm »
Thanks I'll give that a shot, but this is a brand new XP installation so I don't think I've had a chance to pick up a virus yet!
  • Last login:Yesterday at 04:18:09 am
« Reply #3 on: July 25, 2011, 06:12:07 pm »
If you're using the patched ATI drivers then that's the problem, HS won't start if total number of video modes in the system is more than a hundred or so.
ahofle
« Reply #4 on: July 26, 2011, 12:46:30 am »
Crap that must be it, I am using them.
Any idea why Hyperspin cares how many resolutions are defined?
Dazz
  • HyperSpin Team
    • VPUniverse
« Reply #5 on: July 26, 2011, 02:58:03 am »
Because it's a bug in one of the Adobe plugins that is used...
ahofle
« Reply #6 on: July 26, 2011, 12:44:13 pm »
Thanks for the explanation.  I assume Adobe knows about the bug?  Not that this would be a very high priority for them.
« Reply #7 on: March 03, 2013, 09:02:21 pm »
Sorry to resurrect an old thread but I'm curious if there is a workaround for this.  I'm using the patched ATI drivers with GroovyMame.  HS will start when I am remoted into my cabinet but not on the cabinet itself.
« Reply #8 on: March 03, 2013, 10:13:55 pm »
I lowered my number of resolutions in  vmmaker.ini to 90 and Hyperspin will now load.
Sorry for the necromancy.
