Author Topic: TAITO HD! - UPDATE SEPT 1st- Someone please get me a chair.  (Read 27583 times)
dandare
...or some other name- WIP.
Man there are some nice cabs on the forum right now!  OND's ongoing beauty, American Ace, and Matinj's MvC3 baby to name a few.
Its the latter that has inspired me to build my own upright cab.
After a couple of hideous attempts a couple of years ago, I settled on a bartop (which im still very happy with) but that full size beast was still in the back of my mind.
I have always loved classic Taito cabs, and wasn't intending to, but ended up using lokesen's plans again (my bartop was a Wee-cade spawn)
I'd been doodling for a couple of weeks, then the other morning woke up, went out and bought MDF, and what follows is after a 13 hour cutting frenzy!
« Last Edit: September 01, 2011, 11:55:45 am by dandare »
dandare
Re: TAITO HD!
« Reply #1 on: July 24, 2011, 04:54:04 pm »
Toying with button options.
Sanwa- are a long time trusted fight-stick friend 'O mine
But concave Happ/ IL arcade buttons scream old-skool nostalgia...
Re: TAITO HD!
« Reply #2 on: July 24, 2011, 05:04:03 pm »
You're off to a great start. I'll throw my vote in for the concave buttons.
dandare
Re: TAITO HD!
« Reply #3 on: July 24, 2011, 05:39:29 pm »
Thank you sir.
Yeah I'm leaning toward the concave.
I'm putting a PS3 and PC inside, and the sanwa's are only in mind for some hardcore MVC3 action, but i have fightstick.
  • Last login:Today at 05:01:03 pm
Re: TAITO HD!
« Reply #4 on: July 24, 2011, 07:17:16 pm »
+1. Will be nice to see this take shape.
dandare
Re: TAITO HD!
« Reply #5 on: July 25, 2011, 04:21:48 pm »
just scored a 2 player coin door on ebay for £1! (+ £10 postage)
although it may only be the door and not the surround bit?  oh well only a £1
Woodshop Flunky
Re: TAITO HD!
« Reply #6 on: July 25, 2011, 04:57:15 pm »
Looks good!  I love the Taito cabs.  Keep it up.  :applaud:
dandare
Re: TAITO HD!
« Reply #7 on: July 26, 2011, 12:44:07 am »
Thank you.  your cab has been a big inspiration!
seniyajw
  • Last login:July 26, 2011, 01:13:51 am
Re: TAITO HD!
« Reply #8 on: July 26, 2011, 01:09:14 am »
simply connect it to you ipac, one cable ground - the other swX. you can place it everywhere you want, bottom or sidewall is a good idea. just test it.
dandare
Re: TAITO HD! - UPDATE AUG 2nd
« Reply #9 on: August 01, 2011, 07:50:53 pm »
Got my slot cutter from T-molding.com today (Monday)  I wasn't expecting it to arrive for a few more days, great stuff!
Anyway i got down to some routing and cutting, I was a slot cutting virgin, but no more!
(I cant believe i was worried, it was the simplest and most satisfying routing i've ever done!)
So here's what i did today.
dandare
« Reply #10 on: August 01, 2011, 07:53:07 pm »
Gave my £1 coin door a fresh coat of paint. Cleaning up the parts too, its so cool!
It came without the frame, so i'm making one out of plywood.
« Last Edit: August 01, 2011, 07:56:18 pm by dandare »
dandare
« Reply #11 on: August 01, 2011, 07:58:16 pm »
before and after
dandare
« Reply #12 on: August 01, 2011, 08:05:47 pm »
Went round with the router to make both sides the same.
T-moulding slot cut.
Rear vents cut (i didn't ruin it with anything too fancy, they will have mesh inside)
Front accsess door, which will have the coin door, volume knob, and a couple of usb ports on it.
2.1 Speakers
And the resulting mess!
dandare
« Reply #13 on: August 01, 2011, 08:15:11 pm »
I definitly want to laminate and found what i think is a good place/deal
http://www.selffit-worktops.co.uk/products.php?product=Formica-Laminate-Sheet-3050x1300mm-6469-Sea-Blue-delivered-rolled-and-boxed
I'll probably need two lots if i want the back of the cab done too.
I've not really thought of artwork yet (but deinitly plan on having side art, cp and marquee), but in the mean time want it too look nice with just laminate
Here's a rough (very rough) idea, or may reverse the colours, ie. white laminate, blue t-mold?
Well Fed Games
  • Delicious!
« Reply #14 on: August 01, 2011, 08:42:07 pm »
Love the design... man, painting is a chore. I would definitely consider laminate for my next cab.
dandare
« Reply #15 on: August 01, 2011, 09:17:09 pm »
Thank you!
I painted my first bartop, which I didn't mind, but after seeing some of the great laminated cabs on the forum, it was a no brainer.
Loving your pacman cab!, keep up the good work. :cheers:
dandare
Re: TAITO HD! - UPDATE SEPT 1st- Someone please get me a chair.
« Reply #16 on: September 01, 2011, 11:57:53 am »
Bit of an update…
Changed a few things, decided against the laminate in the end (i'm sure i'll regret it), found some grey paint for floors.
It gives a nice hard wearing and smooth finish (although i still need to apply a couple more coats)
dandare
« Reply #17 on: September 01, 2011, 12:02:00 pm »
After test playing for about half an hour i realized that i'm not a kid anymore and need to sit down!
So i chopped about 20cm of the bottom so its sit down height.
Which is an added bonus for playing console/emulators with a pad.
Speaking of game pads, i've kinda borrowed ideas from several projects. A 2 port snes - usb hub, and 2 dreamcast extention ports on  the front.  Along with the volume control
Still a little rough in places, I haven't hammered in the t-mold properly (need to get a rubber hammer), and need to adjust the control panel (or may make a new one.)
Martijn
  • Akira!
    • ModMyBox
« Reply #18 on: September 01, 2011, 12:19:41 pm »
Nice to see you still working on it. Taito Tablebartop HD  :laugh:
dandare
« Reply #19 on: September 01, 2011, 12:23:55 pm »
HA HA thank you. Its not that short.
dandare
« Reply #20 on: September 01, 2011, 12:41:25 pm »
Illuminated buttons (well the will be)
And coin catcher (thanks for the idea Martijn  ;D)
« Reply #21 on: September 01, 2011, 01:05:12 pm »
But... sitdowns are designed with leg room in mind. Isn't that going to be an issue? Also, is your control panel loose or is it actually sticking out further than the T-Molded sides?
dandare
« Reply #22 on: September 01, 2011, 07:00:16 pm »
I have tested it with a couple of friends and it seems fine, i'm happy with the leg room.
There's not as much room as say a Naomi or an Egret.
The cp isn't secured in the photos thats why it looks funny, it will stay within the t-mold boundaries.
I've actually kept the cut down pieces, i may make a nice flush base box, should i ever want it at standing height.
