Author Topic: New lightgun plugin for pcsx-r  (Read 11796 times)
GreatLamer
  • Last login:July 17, 2025, 04:27:37 pm
« on: July 24, 2011, 04:11:54 pm »
A new lightgun plugin (and pcsx-r with lightgun mod) launched today.
Nuvee PSX controller plugin
http://forums.ngemu.com/showthread.php?t=143143
Included source and modified pcsx-r.
Support guncon games in guncon/mouse mode via mouse or lightgun, even in dual mode in any resolution.
Good plug-in for my EMS Topgun II's. Sure you guys also will use it for lightgun gaming.
Thanks to the author!
Haggar
  • Last login:February 13, 2017, 05:12:32 am
Re: New lightgun plugin for pcsx-r
« Reply #1 on: July 27, 2011, 02:40:59 am »
Have you tried it? Can you make some comparison with WinGun driver?
It works also with PC games (troubleshooter)?
GreatLamer
« Reply #2 on: July 27, 2011, 05:31:18 pm »
Please don't confuse things. Just read it, not write only. This is a plugin for PCSXR, you use as lightgun as you want. And no, not works with PC games and this isn't a troubleshooter.
GreatLamer
« Reply #3 on: September 28, 2011, 05:02:12 am »
Now the plugin supports PCSX2, too. Lightgun, mouse and keyboard emulation shouldn't be a problem.
Shun
  • Last login:December 09, 2025, 05:14:48 pm
« Reply #4 on: September 28, 2011, 07:37:28 am »
I've tried this plugin over the last couple of days and it works great with the mouse as it has a cross hair. My Aimtrak should be arriving soon so will be able to do some testing  ;D
Complete: Pac-Man Cabaret scratch build:
Project thread
Work in progress:
Two Phase Bartop With Flush Mounted Dreamcast. 75% Complete
Shun
« Reply #5 on: September 30, 2011, 05:53:05 pm »
I can confirm that it works great with the Aimtrak, fullscreen @ 800x600.
There is a separate setting for each game so I have had to run each PS1 light gun game as an individual batch file in Maximus Arcade using the PCSXR command line, but I don't have a problem with that as I can now play Time Crisis with my new Aimtrak!  :applaud:
Project thread
Work in progress:
Hunk_4TH
  • Last login:August 11, 2025, 07:03:04 pm
  • I DON'T ALLOW VANDALISM IN MY STOOOOOOOOOOORE!
« Reply #6 on: October 01, 2011, 08:03:40 pm »
This is very good news! However I can't seem to get it to work for me. I'm trying Resident Evil Dead Aim using mouse/keyboard but it doesn't do anything. I set the controller to none then choose Guncon2 and selected RE Dead Aim profile but it doesn't work for me :( Even tried from original disc with same result.
Hunk_4TH
« Reply #7 on: October 02, 2011, 03:01:14 pm »
Anyone have any ideas? I'm using the PCSX2 build that's included with the plugin.
*Edit* Nevermind guys I didn't have use keyboard as D-pad selected :(
« Last Edit: October 02, 2011, 03:09:45 pm by Hunk_4TH »
robertwillton
  • Last login:December 06, 2011, 10:49:35 pm
« Reply #8 on: October 13, 2011, 03:48:44 am »
Well This will release the device and re-acquire the correct way. If the lightgun name changes everytime you plug it in, you'll need to re-acquire anyways. :(
robertwillton
« Reply #9 on: October 13, 2011, 03:49:53 am »
