Author Topic: J-Pac issue  (Read 1284 times)
swoon
  • Last login:April 24, 2014, 06:09:43 am
J-Pac issue
« on: July 23, 2011, 05:12:14 pm »
Hi,
I just installed my Mame cabinet using a J-Pac on a Windows XP -SP2 machine. Mala Front-end and Soft 15Khz
System boots into Mala fine, however 95% of the times I need to unplug and reinsert the J-Pac USB cable in order to get the controls working. (Video is fine. All leds on the J-Pac are lit)
Windows comes up that the USB device is not working properly, after reinserting the USB plug it reports the device as working correctly.
Is this a known issue? Anybody knows a solution?
On the other hand, is there a tool or script that I can run on Mala startup that resets the USB devices so the J-Pac gets initialised correctly? (Or are there any j-Pac drivers?)
Mark Thomas
  • Last login:August 16, 2014, 07:41:56 am
Re: J-Pac issue
« Reply #1 on: July 24, 2011, 09:31:35 pm »
Have you tried plugging it into a different USB port? Try it and see if it still happens
swoon
Re: J-Pac issue
« Reply #2 on: August 02, 2011, 04:36:09 am »
Hi,
I just uninstalled the device and had it reinstalled.
Seems to work fine up until now :)
