Author Topic: NOoooo!!! Hard Drive dead ..... use laptop with Windows 7? drivers?  (Read 1328 times)
ragnar
  • Last login:August 16, 2022, 10:40:56 am
My PC hard drive for my MAME Cab is dead.  I have to look at it more tomorrow.
Now, I have a laptop with an i3 Intel chip in it that I was going to sell on Friday.  Should I keep it for the MAME cab?
So, are there any benefits to having newer hardware?  My PC had trouble with Mortal Kombat 3 and a few other games but for the most part it worked.
What about drivers?  I have an iPac and two u360s.
What to do ....?
Thanks,
ragnar.
MY FIRST BUILD:
newmanfamilyvlogs
    • Newman Family Vlogs
Re: NOoooo!!! Hard Drive dead ..... use laptop with Windows 7? drivers?
« Reply #1 on: July 21, 2011, 05:51:52 am »
Sounds like you answered your own question. An i3 should run everything that can run perfect.
ipac and u360s do not need extra drivers.
« Reply #2 on: July 21, 2011, 10:57:49 am »
Laptops usually lack in a good GPU, but that isn't going to make a difference for Mame. Other emulators you may use may rely on a good GPU, though. Emulators for older gaming systems should still be perfectly fine.
For hardware, just make sure you have the physical ports needed, I believe the older ipacs had only the PS/2 ports, and that is not very common to a laptop anymore.
ragnar
« Reply #3 on: July 21, 2011, 04:35:35 pm »
I agreed to sell the laptop ....
Basically, I promised it to a friend before this happened and he actually changed his weekend plans this weekend so he can toy with the laptop.
So I can't back out of it.  The laptop is going by-by
Did consider a new desktop just so I can get Windows 7 but it is $300-$400.
I'm busy in the summer.  I think I'll save the Mame cab redo till this winter which kinda sucks.  If I wait, I can give myself an excuse to get a new desktop.  Actually, i wanted to replace the main PC in our home anyway.  Probably get two!
MY FIRST BUILD:
newmanfamilyvlogs
« Reply #4 on: July 21, 2011, 04:46:27 pm »
you could just replace the harddrive in the old machine, couldn't you?
