Author Topic: Donkey Kong lower Marquee bracket!!!!!!!  (Read 2765 times)
mytymaus007
« on: July 18, 2011, 09:41:15 pm »
Does anyone have a good picture of a lower marquee bracket for Donkey Kong, if so a close up of the side view and front view That would be great so far i have seen one from Mike's Arcade but it is a very small picture. :cheers:
« Last Edit: July 19, 2011, 08:40:24 am by mytymaus007 »
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:February 23, 2026, 07:55:20 am
Re: Donky Kong lower Marquee bracket!!!!!!!
« Reply #1 on: July 18, 2011, 10:29:12 pm »
If you don't get a good picture by this weekend remind me and I will get pictures of mine.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
mytymaus007
« Reply #2 on: July 18, 2011, 10:43:22 pm »
no doubt im trying to figure out if the top part of the bezel slides into the lower marquee bracket. I have a custom caberet that i bought and the bezel goes to the top of the cab. it was originally a vertical cab,I put in a horizontal lcd. i think i can build an area for the marquee simliar to Donky Kong. :dunno
mytymaus007
Re: Donkey Kong lower Marquee bracket!!!!!!!
« Reply #3 on: July 20, 2011, 08:25:58 am »
no pics yet :dunno
gabe
  • Last login:September 10, 2012, 12:44:38 pm
« Reply #4 on: July 20, 2011, 09:46:46 am »
I do not have a picture of this bracket!!!!!!!
« Reply #5 on: July 20, 2011, 10:02:35 am »
Since it's a custom cab, it probably makes more sense for you to post a picture of the cab.
On a typical Donkey Kong narrow body cabinet, the top of the bezel is held on by the bottom of the marquee and the cabinet. There is a adjustable metal rod which also holds the bezel in place. The lower bracket snugly fits around the bezel and fits into a slot cut into the piece of wood above the control panel.
mytymaus007
« Reply #6 on: July 20, 2011, 02:16:04 pm »
Thats what I thought. It sounds like it will fit my cab with a little modification
