Author Topic: how can I sort my mame roms  (Read 4835 times)
dreamfreak
  • Last login:August 23, 2005, 08:10:58 am
« on: September 05, 2003, 03:34:57 pm »
hi,
I
SpAwN
  • Last login:August 09, 2006, 01:41:48 pm
  • Mame Cab done, working on restoring a Wurlitzer
Re:how can I sort my mame roms
« Reply #1 on: September 05, 2003, 04:51:27 pm »
http://www.mameworld.net/catlist/
From the help page...
1. Unzip the file into the MAMEWAH folder.
    You might want to give it a subfolder or rename it
    so you can use multiple files.
2. In MAMEWAH, go to
    "Emulator Settings -> List Generation Settings",
    and set "CatVer Filename".
3. Refresh the games list.
« Last Edit: September 05, 2003, 04:52:09 pm by SpAwN »
dreamfreak
« Reply #2 on: September 06, 2003, 12:42:40 pm »
In MAMEWAH, just point to your catver.ini in the 'Emulator Settings' > 'List Generation Settings' section.  Refresh the list and you will then be able to view+filter by said categories
thank you for your help
now mamewah display
Rocky
  • Last login:December 30, 2009, 12:38:41 pm
  • I want to finish my cab before I retire!!
« Reply #3 on: September 06, 2003, 01:56:48 pm »
Even after you choose the method, rom only etc., you can sort the list by categories (it uses catver.ini)
I recommend rom folder vs listinfo
Then, filter the categories for the ones you want.
dreamfreak
« Reply #4 on: September 06, 2003, 03:36:09 pm »
I don
dreamfreak
« Reply #5 on: September 07, 2003, 12:10:59 pm »
hi,
I don
dreamfreak
« Reply #6 on: September 07, 2003, 01:52:10 pm »
now I got it
I had the wrong path for the catver.ini
