Author Topic: Mounting plexiglass for monitor  (Read 4975 times)
emb
  • Last login:September 14, 2018, 02:01:19 pm
    • Don Honerbrink
« on: July 13, 2011, 09:08:28 pm »
I finally got my monitor and came into a design problem, I not quite sure how to mount the plexi onto the  cabinet. I would expect this to be an easy task but the monitor stand does not rotate much. I was hoping to get the plexi to be flush with the monitor. This causes a huge gap in between my control panel and monitor. Any ideas?
Donkbaca
    • Slim built MAME/Xbox cab
Re: Mounting plexiglass for monitor
« Reply #1 on: July 13, 2011, 10:03:22 pm »
Get foam core board to put between the glass and the monitor or take off the stand
TopJimmyCooks
« Reply #2 on: July 13, 2011, 10:05:12 pm »
on the mounting:  you've already finished and installed your admin panel - often a slot routed in the top of that holds the bottom edge of the glass.  you could cut an L shaped piece to mount behind it and hold the face of the plexi tight to the back of the admin panel.  that would take care of the bottom.  the top is easy, just mount some blocks behind the plexi that push it tight to the back edge of the speaker panel.  then, you slide it in and the top and drop it down into the bottom slot.
a good lcd monitor mount from Knievel
On the monitor angle, I would recommend that you take off the stand and use the vesa mount points on the back of the LCD to hard mount it to the cab, at the same angle as your plexi.  you don't want your display loose inside the cabinet.
