Author Topic: Trackball as mouse  (Read 1240 times)
hellothere123
  • Last login:March 02, 2021, 03:39:27 am
Trackball as mouse
« on: July 13, 2011, 02:49:19 am »
I know the trackball works as a mouse, but do you have to install buttons for the select function?
Blanka
Re: Trackball as mouse
« Reply #1 on: July 13, 2011, 03:48:48 am »
It depends on the controller used.
I use a Minipac for wiring a 2.25 inch ball, and with the new iPac you have to move 2 pins from the harness to another position as the mouse-button pins are empty by default. But this is a very easy mod. Just use a very small screwdriver to release the pin from the plastic.
