Author Topic: outrun project  (Read 4233 times)
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
outrun project
« on: July 09, 2011, 09:54:01 am »
Hi
Hello everybody I'm relatively new here. I built a machine style OUTRUN details in my blog, sorry but the information in Hebrew! Anyway there are pictures of the whole process.
http://jackiabu.blogspot.com/ 8)
p.s.  i just add the new google translate :applaud:
[img][img]
« Last Edit: July 09, 2011, 11:02:50 am by jackiabu »
  • Last login:November 21, 2025, 10:39:28 am
Re: outrun project
« Reply #1 on: July 09, 2011, 12:16:54 pm »
The design of the cab and artwork look great!
I don't care for the gauges mounted to the side (but it's your cab).
Unless there's room above the steering wheel, I think it would look better without them.
Or maybe you could build a dashboard with the speedometer on one side of the wheel and the tachometer on the other.
I dreamed of Ferrari parts too, but I think my whole cab cost less than a Ferrari gas pedal.
Check out the "driving cab info thread" link in my signature for a list of other emulators you can install.
Every computer based driving cab should have Nebula's Sega Model 2 emulator!
jackiabu
Re: outrun project
« Reply #2 on: July 09, 2011, 02:01:46 pm »
First of all thank you very much for your help. :laugh:
Listen I think you're really an expert in the field of car-style arcade machine.
Anyway I downloaded the emulator of NEBLUA SEGA and it's not working for me, can you help me with this?
I downloaded the file from the site but I opened it but nothing happens.  :banghead:
gbeef
    • arcadepix.com
Re: outrun project
« Reply #3 on: July 09, 2011, 03:00:49 pm »
You also need horse power to run nebula at least Athlon X2. or a Duo core chip machine.
Nice build Love the way you did the back of the cabinet
My cabs
4 Player Arcade
X-men Arcade Remixed
Re: outrun project
« Reply #4 on: July 09, 2011, 03:58:27 pm »
The newest release requires that your runtimes be up to date:
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=5555
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=35
The roms it uses are the same as MAME.
If it still doesn't work, let us know exactly what it's doing.
Pinball Wizard
Re: outrun project
« Reply #5 on: July 11, 2011, 08:24:42 am »
One issue to look out forit that the speakers on top often monitormay discolor it over time.
Where's my gold star :P
Re: outrun project
« Reply #6 on: July 11, 2011, 09:30:23 am »
He's using PC speakers, so it won't be a problem;they're shielded.
Namco
  • Last login:November 14, 2025, 12:56:14 am
    • Freddo Mame Project
Re: outrun project
« Reply #7 on: July 11, 2011, 10:14:25 am »
Wow, that looks great. I wonder if the PC has a version of Outrun that will take advantage of that wheel's force feedback, that would be incredible. Also I think you missed a great opportunity to mount speakers by the player's head. Having some bumping speakers next to the player is something I remember from a few cockpit drivers. I have an old TSW2 steering wheel that I have been dying to put into a cabinet. This is giving me some ideas. ;D
Re: outrun project
« Reply #8 on: July 11, 2011, 07:18:27 pm »
http://www.oocities.org/finalburnff/
Your question got me looking into this again.  I'd heard there was a version of Final Burn that supported FFB, but all I came across before were some code to add to the newer build to add rumble support.  That doesn't do anything for wheels.  After your comment, I searched again and found the link above and it sounded like it worked with an actual wheel.  I gave it a try and it does!!!
Setup is a bit of a PITA.  I don't want to derail jackiabu's thread with the details.
I'll add them to the driving cab thread shortly and mark it as updated as of today.
jackiabu
Re: outrun project
« Reply #9 on: July 12, 2011, 01:03:40 pm »
ok i download the file m2 emulator,extract and run it.my question is where i put the rom file? :-\
thanks ahead
Re: outrun project
« Reply #10 on: July 12, 2011, 01:28:47 pm »
thanks ahead
There should be a rom folder in the same folder as the m3 emulator.
If there isn't, just make one.
jackiabu
Re: outrun project
« Reply #11 on: July 12, 2011, 02:42:49 pm »
thanks ahead
i make rom folder' but still no luck'i allso try folder same as the exe' what i do worng? :dizzy:
Re: outrun project
« Reply #12 on: July 12, 2011, 03:34:31 pm »
