Author Topic: U360 Wiring Harness in Output Mode- Not working any Advice?  (Read 1076 times)
Charles4400
  • Last login:February 18, 2016, 02:31:42 am
Hi All,
I have 4 x U360s on my panel and just put 4 wiring harnesses on them in output mode to attach to my ipac.
2 of them work and 2 do not recognize the wiring harness at all.
All sticks work in analog mode.
But in 'switch mode' I get nothing from 2 of them.
It's not the harness as I switched the bad boards harness with known working harnesses and there was still no output.
I also put the harness from the 2 bad boards on known working boards and they did output properly. So harnesses should be fine.
I also tried the boards in 5v mode without the USB and stil got no output.
Has anyone experienced this or is this just a case of haveing bad boards sent in 2 of the sticks?
I contacted  Andy but think he still on vacation...so was just wondering if anyone here experienced this and had a fix?
Thanks,
Charles
syph007
Re: U360 Wiring Harness in Output Mode- Not working any Advice?
« Reply #1 on: July 08, 2011, 11:24:48 pm »
Do all the sticks have the same firmware?
