Author Topic: FE that supports U64/KIAME ?  (Read 8169 times)
GameAddict
  • Last login:January 16, 2004, 05:07:55 pm
« on: July 10, 2002, 11:11:39 am »
Hi!
Is there anywhere a frontend that supports next to MAME the U64 Killer Instinct Emulator? Thanks  ;D
  • Last login:March 11, 2026, 10:21:07 pm
Re: FE that supports U64/KIAME ?
« Reply #1 on: July 10, 2002, 02:13:15 pm »
There's only one.  Raging Dragon.
http://www.oscarcontrols.com/dragon/
GameAddict
« Reply #2 on: July 11, 2002, 02:50:44 pm »
Is there anywhere a tutorial for setting RD up? I have some problems with RD, the menu takes hours to respond to up/down commands, and it crashes after trying to load a rom (blank screen and then it crashes)
« Reply #3 on: July 11, 2002, 06:59:48 pm »
rd is a dead project and is thus no longer supported... stay tuned for the rebirth
StephenH
« Reply #4 on: July 12, 2002, 02:36:11 am »
x-wing
  • Last login:March 28, 2003, 10:40:37 pm
  • I Built My Own Arcade Controls!!
« Reply #5 on: July 12, 2002, 11:09:12 pm »
GameAddict-- did you run the Runme.bat file? You should also double check the dragon.ini file to make sure your paths are set correctly.
HC - haw!  point the guy to your frontend, then then tell him it's not supported anymore when he has a question.  come on....  you wrote the thing, help out.
« Reply #6 on: July 13, 2002, 02:59:39 pm »
HC - haw!
