Author Topic: Simple 12v delay circuit?  (Read 6722 times)
jimmy2x2x
« on: July 05, 2011, 01:33:57 pm »
I was wondering if there is a simple circuit I could build to delay 12v from a pc power supply molex for 5 seconds when power is applied, after 5 seconds it should remain continuous.
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
Re: Simple 12v delay circuit?
« Reply #1 on: July 05, 2011, 01:42:29 pm »
A 555 timer circuit driving a relay (via transistor switch) should work fine.
jimmy2x2x
« Reply #2 on: July 05, 2011, 01:43:52 pm »
excellent, could you translate into spazomatic for me please?
(uk parts links would be very welcome)
I have no idea!
Bender
« Reply #3 on: July 05, 2011, 01:51:02 pm »
I don't know about making one but they make such a device for car custom a/v installs
can't remember what they're called off the the top of my head though, used one to delay the monitor coming on
ahh, here is the thread where I asked a similar question
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #4 on: July 05, 2011, 03:14:11 pm »
Here's my try at it, assuming my memory serves right!
10nF Cap - ECQ-V1H103JL
Diode on Relay - 1N4004
Relay - G5LE-1 DC12
BJT NPN Transistor - TIP29C
555 Timer - LM555C
4.7k Resistor (1/4 Watt, 5%) - Get it anywhere!
1000uF Capacitor - ECA-1EM102B
Here's the schematic. As with anything you see, check it for sanity! (I'm at work and rushed. :P)
bkenobi
« Reply #5 on: July 05, 2011, 06:35:13 pm »
This might be useful.  I've wondered how to set the delay on a 555 before but never checked.  This is a calculator.
http://clarkson-uk.com/555-timer/operation/frames3.html
It looks like a set capacitor value with a rheostat would provide a variable delay.  Find an appropriate sized capacitor for the rheostat you want to use and you're good to go, right?
  • Last login:January 26, 2026, 08:08:49 am
boardjunkie
« Reply #7 on: July 05, 2011, 10:25:52 pm »
10k resistor with a 470u cap gives a time of 5.1 secs.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #8 on: July 10, 2011, 07:10:45 pm »
What are the details of the application?
-Banned-
jimmy2x2x
« Reply #9 on: July 10, 2011, 07:29:46 pm »
Postpone power switching to TV, so I can apply power to all devices at once, postpone switching for a couple of seconds, then apply power to select correct scart channel.
Looks like there are some great solutions here, I have not had chance to experiment yet.
