Author Topic: U360 Wiring Harness Question  (Read 3538 times)
Charles4400
  • Last login:February 18, 2016, 02:31:42 am
« on: June 29, 2011, 07:30:17 am »
If you use both the wiring harness attached to ipac and USB for the U360 would you get the best of both worlds by 1)allowing mapping to still be used MAME as well as 2) allowing keyboard movement controls on some PC games that don't support joysticks (joypads)?
OR as soon as the U360 is attached to the ipac, does it lose its mapping ability?
Anyone have experience with this?
-Charles
Re: U360 Wiring Harness Question
« Reply #1 on: June 29, 2011, 08:19:16 am »
You would still be able to map the U360, but you will lose analog (if that matters to you). The U360 is basically a mappable switch type joystick when wired like that.
Charles4400
« Reply #2 on: June 29, 2011, 03:14:25 pm »
Hmmm then I assume it would not work without custom maps for games like Qbert with 45 degree rotated layout?
« Reply #3 on: June 29, 2011, 05:11:41 pm »
Yes, it will still work. As long as it is hooked up to USB, it is mappable. You can map the U360 to read only diagonal directions.
rcub3
  • Last login:May 31, 2017, 04:56:23 pm
« Reply #4 on: June 29, 2011, 11:21:32 pm »
Hmmm. So what is the benefit of connecting it to the ipac too?  Wouldn't the USB connection do all of it(mapping, analog, etc)?
Charles4400
« Reply #5 on: June 29, 2011, 11:51:14 pm »
Hmmm. So what is the benefit of connecting it to the ipac too?  Wouldn't the USB connection do all of it (mapping, analog, etc)?
I was thinking to play some PC games with keyboard control movement only...
Blanka
« Reply #6 on: June 30, 2011, 02:27:11 am »
Do you mean you can attach a U360 to a minipac for standard up/left/right/down keyboard buttons, and have it seen as USB game controller at the same time? That would be awesome. It is the main reason I don't use U360s for main controllers now, as sometimes I need them to act as keyboard.
Blanka
« Reply #7 on: June 30, 2011, 02:31:54 am »
Wel it seems so:
I/O Port is used as Output.
USB is connected    I-PAC, J-PAC etc    Fully Mappable Analog/Digital joystick
Cell matrix mappable to any 8-way direction, sticky
or center, or analog.    4 Direction wires to emulate switches.
Responds according to the defined map (downloaded via USB).
Any analog cells are treated as center.
http://ultimarc.com/ultrastik_inst.html
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #8 on: June 30, 2011, 02:33:27 am »
That's correct, the U360 has always had this capability.
Andy
Charles4400
« Reply #9 on: June 30, 2011, 05:24:04 am »
So is it correct that it will lose analog functionality if the directional wires are used ?
« Reply #10 on: June 30, 2011, 07:08:04 am »
That's how I read this:
