Author Topic: Interest in 20" 4:3 LCD monitors?  (Read 4553 times)
alfonzotan
  • Last login:August 10, 2025, 04:06:03 pm
    • The Cab With No Name
« on: June 28, 2011, 01:36:56 pm »
I may be able to get a number (not sure how many or which brand/model at this point) of used 20" 4:3 aspect ratio LCD monitors.  They'd probably sell for $100 plus shipping (from GA).  Any interest?
I'd test beforehand for bad pixels/screen damage, but otherwise these would be used stock, DOA warranty only.
Re: Interest in 20" 4:3 LCD monitors?
« Reply #1 on: June 28, 2011, 01:41:19 pm »
Do you know the brand?
alfonzotan
« Reply #2 on: June 28, 2011, 01:51:53 pm »
Nope.  HP would be a likely guess, but I can't commit to that at this point.  I would find out the brand and model(s) before taking any orders.
Red
  • Last login:November 07, 2017, 08:37:51 am
« Reply #3 on: June 28, 2011, 04:47:52 pm »
I'd be interested.
« Reply #4 on: June 28, 2011, 04:53:30 pm »
Depends on if it is a S-IPS panel or TN panel...
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #5 on: June 28, 2011, 05:11:28 pm »
They are probably PVA or IPS, most of the TN stuff is the newer widescreen junk
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:February 11, 2026, 06:56:49 am
« Reply #6 on: June 30, 2011, 08:27:42 am »
Can you get the mounting dimensions please?
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
TopJimmyCooks
« Reply #7 on: June 30, 2011, 09:53:29 am »
interested.
alfonzotan
« Reply #8 on: June 30, 2011, 01:54:12 pm »
Okay, I'm going to take all this as a "yes"... I'll get the details and post an update.  Might be a few days, though.
Thanks...
alfonzotan
« Reply #9 on: June 30, 2011, 01:57:36 pm »
Saint, do you mean the external dimensions, or the back-panel mount dimensions (or both)?
saint
« Reply #10 on: June 30, 2011, 02:46:12 pm »
External dimensions, i.e. can I squeeze it physically into my cabinet :)
--- John St.Clair
     Project Arcade 2!
alfonzotan
« Reply #11 on: June 30, 2011, 03:21:30 pm »
That's what I figured.
SNAAKE
  • Trade Count: (+29)
« Reply #12 on: June 30, 2011, 03:33:10 pm »
whats the difference between ips and tn??
emb
  • Last login:September 14, 2018, 02:01:19 pm
    • Don Honerbrink
« Reply #13 on: June 30, 2011, 03:50:54 pm »
Depending on the monitor specs (brand, physical dimensions, resolution, contrast ratio, etc...); I'm interested. I'm looking for a monitor to fill my new cab.
« Reply #14 on: July 01, 2011, 10:06:51 am »
TN sucks for a cab...  poor viewing angles.  IPS has better angles, and can be used horiz or vert, no problem.
Donkbaca
« Reply #15 on: July 01, 2011, 12:09:33 pm »
It has to do with the way the LCD crystal are activated and aligned.
A quick rundown of the different, most common panel type:
IPS: Advantage - Best color reproduction, best viewing angles horizontal and vertical, we are talking 178 degrees here.   Disadvantage - A little slower than TN, expensive, hard to find.
PVA: Advantage - Best contrast of the types.  This one has the blackest blacks.  Great viewing angles, though not as good as IPS ( we are still talking in the 170 degrees + here, horizontal and veritcal) , 24 bit color, but not quite as good as IPS due to slight color shift off center.  Disadvantage -  Response time is the slowest, slight color shift off center compared to IPS, but better than TN
TN: Advantage - Fastest reponse time, cheapest, easiest to find.  Disadvantage- Does not display true 24 bit color, can only produce 18 bit color and uses dithering to compensate, which leads to a more pixelated look; Worst contrast ratio of the types; worst viewing angles.  The way TN displays are designed, the crystals are perpendicular to the display, so the viewing angles are the worst, while most would find them acceptable horizontally, vertically they are really bad.
Here is my opinion:
IPS - in my opinion is overkill.  They are hard to find, and expensive.  The advantage they give - superior color reproduction and viewing angles is, in my opinion, lost in an arcade cab where you are mostly going to be standing right in front of it, so viewing angles aren't that important, and the images aren't going to be 24 bit anyway.
PVA - I think this is the best option.  They are pretty easy to find and reasonably priced.  The advantage they give - contrast ratio, is in my opinion the best of the advantages.  The disadvantage - response time, is something that doesn't matter that much.  In short response time is sort of a ---That which is odiferous and causeth plants to grow--- comparison tool due to the fact that there is no universally standard way to measure it, and people confuse that with input lag, which is different than response time.  Anyhow, get one that is under 20ms and you will be fine.
TN - Really isn't a bad way to go, unless you want to vertically mount the monitor, or use it in a cocktail.  The disadvantages - color reproduction and viewing angle, don't really matter IMHO when it comes to a cab.  Most of the games in your cab will not have 24 bit color, and you will be playing the cab standing right in front of it, so viewing angles don't matter. These are cheap easy to find.  I think most people would be happy with a TN monitor
I use a PVA panel, I love it.  The viewing angles are fantastic, I don't notice the color shift at all when viewing from an angle, I love the contrast on it, the blacks are really, really black.  I don't notice any lag at all, the picture is just great looking.  I would recommend a PVA to most people.
« Reply #16 on: July 01, 2011, 12:19:10 pm »
I just bought a 20" IPS on ebay for under $100 shipped...   :applaud:
« Reply #17 on: July 01, 2011, 12:32:20 pm »
Well, if these aren't TN and have no pixel issues, I'm interested.
