Author Topic: WG k7200 & arcade VGA questions  (Read 2181 times)
jimsam
  • Last login:January 11, 2004, 04:37:58 pm
« on: September 03, 2003, 04:18:45 pm »
I just ordered a Wells Gardner K7200 19" monitor. I am going to order an ArcadeVGA card this weekend or when they are finished with their holiday.  :)  1st question: My cabinet was empty when i got it, so what is the best way to power it? a power supply? or could you hook up a standard power cord to the monitor to plug in my power strip? and what about grounding the monitor?  Question 2: wiring the cable. I noticed on the ultimarc website they had a premarked cable that only uses 6 connections. What about the others ones on the monitor like the key, - vertical sync (not +v sync)  and the extra ground?
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
Re:WG k7200 & arcade VGA questions
« Reply #1 on: September 03, 2003, 06:21:27 pm »
jimsam
« Reply #2 on: September 04, 2003, 03:33:28 pm »
That link may be dead, I've tried all day with no luck.  I called Happ Controls and they said "With the k7200 having a built in isolation transformer, all you need is a standard ac cord and you can plug it into the wall" does this sound  right?
tom61
  • Last login:September 18, 2017, 12:46:56 am
« Reply #3 on: September 04, 2003, 07:03:35 pm »
Yeah, that sounds right. Most newer monitors have an isolation transformer built in. So, all you need is an AC cord.
Note for others: An older arcade monitor will likley need a separate isolation transformer.
jimsam
« Reply #4 on: September 04, 2003, 09:18:43 pm »
Hey thanks alot, I just got an email back from Wells Gardner and they confirmed that,  luckily I bought the cord from them too, They didn't have a picture or description of it when I placed the order so I just gambled on it.  He did STRESS the fact that any older monitors NEED AN ISOLATION TRANSFORMER, and from what I have been reading serious things can happen without one and you can't hurt anything by using an isolation transformer, so if someone can confirm that I would feel better about anyone reading this thread. So I hope no one ever takes that chance.
