Author Topic: Painting MDF [the lazy way] and getting a decent look  (Read 3502 times)
Gray_Area
  • -Banned-
  • -Banned-
« on: June 27, 2011, 04:14:58 am »
I tried the 'sealer' method Fozzy suggested in the 'Painting MDF' thread, and that didn't work for me. Also, I don't need a smooth finish, and I'd rather play games than build cabinets.
There are two ways: the lazy way; and the really lazy way. Either of these gives a finely textured finish - AND REQUIRES NO SANDING. You will need:
- paint
- primer (not needed for the 'really lazy way')
- foam roller and pan
- small brush, and maybe an edger
- can lid spout thing (these are wonderful)
Here's a piece of 1/2 MDF done with only two coats of paint (the really lazy way) :
Here's a piece of 1/2 MDF primed one coat, then painted three coats:
Take into account your environment. If it's really hot and dry, each coat will take maybe 20 minutes to dry and decently cure. If it's really cold and wet, a few hours to overnight may be necessary between each coat.
« Last Edit: June 27, 2011, 04:42:21 am by Gray_Area »
-Banned-
Gray_Area
  • -Banned-
  • -Banned-
Re: Painting MDF [the lazy way] and getting a decent look
« Reply #1 on: July 01, 2011, 12:38:15 pm »
An additional thought to this is you might want to spray on a clear coat of something (acrylic or whatever).
-Banned-
jrock2004
  • Last login:March 29, 2013, 11:58:18 am
    • JC Web Concepts
« Reply #2 on: July 01, 2011, 02:29:31 pm »
Does it need to be some special paint or just any?
« Reply #3 on: July 01, 2011, 02:35:47 pm »
What color purple is that?
