Author Topic: Correct wiring method for LED buttons?  (Read 1118 times)
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« on: June 24, 2011, 01:11:10 am »
I'm about to order some LED buttons and LED joysticks.  All will by 12V DC.  I've never set these up before and just want to check the correct wiring method.  I just want them to be lit all the time and they will be connected directly to a PC power supply (ie. not to any PACDrive board or anything).
I understand that they get connected pretty much like the buttons microswitches - Daiisy chaining the grounds together and connecting to Ground on the PSU ground.
How about the actual +12V line?  Do they get connected in parallel back to the +12V on the PSU?  Or are they also daisy chained together and then into the PSU?
I read somewhere that the grounds can also be connected directly to the ground of the pushbutton microswitch which goes to the IPAC ground, eliminating some cabling? is this recommended?
Any help/Diagrams would be appreciated.
BobA
  • What Me Worry?
Re: Correct wiring method for LED buttons?
« Reply #1 on: June 24, 2011, 08:46:41 am »
Since each LED is 12V the resistors are built in so you can wire them in parallel with no problem.   So you can daisy chain the 12V and the ground for all your LEDs.   The common ground on the switches is the same as the ground for the  LEDs so you can use it if you want.
